IPCC upgrade ....???
Jun 27th, 2010
dear all
i have 2 cisco call managers ( 4.2(3)sr2) and also i have an IPCC (4.0(5)_build042) i want to upgrade my infrastructure to CUCM 7.x and CCX 7.x
what is the right procedure and tools  to do that with minimal down time and technical difficulties
and thanks in advance
Walter Solano Mon, 06/28/2010 - 08:48
  • Gold, 750 points or more
Hello Amer,
The first detail that needs to be check its if you current hardware support UCCX 7, this can be check in the UCCX compatibility matrix.
http://tools.cisco.com/squish/f7BAe
Also you will need a license upgrade from UCCX 4.0(5) to 7.0(1) that can be requested to Cisco licensing team.
After that you need to follow the procedure that its under the UCCX 7, intalation guide;
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/installation/guide/uccx70ig.pdf
Please rate this post if was helpful
Walter Solano
CCVP, Cisco UCCX Specialist
Cisco IP Communications Express Specialist
