Need help recovering username/password on an 831 router
Jun 28th, 2010
I can't log into my router because I forgot my username and password. I'm using Telnet in Windows Vista. I hit the "o" key then I typ in the IP address. It ask for my username then password but I forgot it. Resetting the router and hitting the break key isn't going to work because I can't get into the router at all. Is there some other way I can reset my username and password.
Overall Rating: 1 (1 ratings)
Reza Sharifi Mon, 06/28/2010 - 00:56
  • Cisco Designated VIP,
    2017 LAN
In order to recover your password, you have to be physical at the router and use a console cable to do the password recovery.  It can not be done using telnet.
Reza
Ganesh Hariharan Mon, 06/28/2010 - 01:02
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Check out the below link for password recovery in cisco 800 series:-
http://www.cisco.com/en/US/products/hw/routers/ps380/products_password_recovery09186a00800942bc.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
HappyBeaver Mon, 06/28/2010 - 01:07
None of that is going to work because I can't get into the router at all. To be able to do everything in that link I would have to have the router prompt in telnet. To get that prompt I would have to enter my username and password in telnet which I can't because I forgot both of them.
glen.grant Mon, 06/28/2010 - 04:58
   You do "not" use telnet to do a password recovery.  You use a terminal emulator like Tera Term  set at 9600,8,n,1  to  get into the "console" port on the router to do the password recovery , it has nothing to do with telnetting into the box to  recover the password... Please follow the directions in Ganesh's link , thats the only way you are going to recover the password .
HappyBeaver Mon, 06/28/2010 - 16:36
Thanks for your help. I forgot that Telnet doesn't use the console port. I ended up using PuTTy and I found my username and password. Haven't had to use a terminal emulation program in a long time so it just slipped my mind. Again thanks for your help.
