Catalyst 2948G Help
Jun 28th, 2010
I am new to Cisco switches and I have purchased a Catalyst 2948G (WS-C2948G used on Ebay and while trying to download documentation on it from Cisco I am finding Catalyst 2948G-GE, 2948G-TX, 2948G-L3. How do I know which one I have? There is no image loaded to it so I don't know if it is a router or just a switch. When I remote to it all I get is rommon. Any help would be appreciated.
Overall Rating: 1 (1 ratings)
Ganesh Hariharan Mon, 06/28/2010 - 01:01
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Check out the below cisco 2948G-GE-TX seires image from front panel:-
http://www.cisco.com/en/US/products/hw/switches/ps606/products_data_sheet09186a00801cfafe.html
Check out the below link for recovering from rommon mode for 2948 switches
http://cisco.biz/en/US/docs/switches/lan/catalyst2948gand4908g/12.0_10_w5_18e/configuration/guide/init_cfg.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
daveenglish Thu, 07/01/2010 - 15:39
Thanks for your reply. It does not look like the
GE-TX in the example you provided, and I already have downloaded the configuration documnet but I don't get the login to start the configuration because no image is installed. So I am trying to figure out which image should be installed? Thanks for your help. Dave
Leo Laohoo Thu, 07/01/2010 - 15:42
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
You need to read the 2nd link Reza's posted:
http://cisco.biz/en/US/docs/switches/lan/catalyst2948gand4908g/12.0_10_w5_18e/configuration/guide/init_cfg.html#wp1028303
Reza Sharifi Mon, 06/28/2010 - 01:02
    2017 LAN
Hi Dave,
Since it boots to rommon that means the device does not have any image on it.  If you want to use it as a layer-2 switch just download the image for 2948G-GE but if you want to use it as a layer-2 and layer-3 device then download 2948G-L3.  You need a CCO account to be able to download an image.
Reza
daveenglish Thu, 07/01/2010 - 15:41
Hello, Thanks for your reply. So if I am understanding your reply, I can
either download a router image, or a switch image? How do I know if the router hard
ware is installed? I received another reply stating my model is a sw
itch only? Thanks, Dave
glen.grant Mon, 06/28/2010 - 04:30
   Somewhere on the switch there is usually a sticker saying what the exact model it is . If its the exact model you say it is then its a layer 2 switch only that only runs  catos , not IOS and is not convertible .It has no layer 3 functions.  The 2948G runs the catos 4000 image .  The unit has been EOL since 2008 and the last image they made for that is  cat4000-k8.8-4-11-GLX.bin .
daveenglish Thu, 07/01/2010 - 15:45
Hi, Thanks for your reply. Yes the model from the sticker is
WS-C2948G. Another reply said I could download either a switch image or a router image. Not sure if that is true? The store I purchased it from is supposed to help but I was trying to get it done sooner. Thanks for the reply. Dave
daveenglish Thu, 07/01/2010 - 15:47
I contacted the place of purchase and they are going to help me install an image, so I will wait for that to happen. Thanks for the help,
