data center question
Jun 28th, 2010
Hi Experts,
Any body having Data Center siwtches,firewall and router config examples and plz provide me cisco works for highend configurations like hardware faiovers if any.
srini
Overall Rating: 3 (4 ratings)
Ganesh Hariharan Mon, 06/28/2010 - 01:20
Hi Experts,
srini
Srini,
Configuration of devices in Data center depends on the flow of application and requirement from the client to build the infrastructure,Like access layer switches act as pure L2 and if you want routing to be done the at distribution layer then L3 switches can do the same and the flow should scan the policies deployed in firewall.Firewall configuration will be done based on the traffic flowing across the firewall.
And most of the Data center in the above cases are deployed in fully redundant fashion.
Check out the below link on firewall active/passive configuration :-
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml
Hope to Help !!
Ganesh.H
