Can Cisco 5510 configure to do dns forwarder?
Answered Question
Jun 28th, 2010
My client is using the public dns but they don't want dhcp to give dns as public dns. They want it to point to firewall then only firewall forward the dns to public DNS. Would it possible for ASA 5510?
Hing
Correct Answer by Kevin Redmon about 6 years 11 months ago
Hing,
Sort of - you could configure a static statement on the ASA that will equate to the DNS's IP address.  For instance:
static (outside, inside) 10.1.1.253 1.1.1.1
You would also have to ensure that UDP 53 traffic is also allowed via access-list on your inside interface.  On your DHCP server, you would then configure the IP address 10.1.1.253 as your DNS server - in reality, the ASA will simply translate that IP address to the real 1.1.1.1 address.
Hope this helps,
Kevin
Overall Rating: 5 (2 ratings)
Correct Answer
Kevin Redmon Tue, 06/29/2010 - 15:45
  • Cisco Employee,
Hing,
Hope this helps,
Kevin
VincentLong Tue, 06/29/2010 - 20:29
Hi Kevin,
Thanks alot. That was a brilliant idea.
Hing
Kevin Redmon Wed, 06/30/2010 - 06:41
  • Cisco Employee,
Hing,
If you have any further questions, please let us know.  If this solution works for you, please be sure to mark this question as answered.
Thanks in advance,
Kevin
