06-28-2010 03:13 AM - edited 03-06-2019 11:47 AM
I notice some of the IOS using c7200p-advipservicesk9-mz.124-24.T3.bin and c7200-advipservicesk9-mz.124-24.T3.bin,
We are running cisco 7206 VXR Router with NPE-G2. what is the benefit of using c7200p instead only c7200?
06-28-2010 06:44 AM
Check out the below link on ios images with explanation on naming convention
http://www.packetstormsecurity.org/defcon10/MoreInfo/CiscoIOSReferenceGuide.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
07-12-2010 04:27 AM
Are you able to get the image "c7200-advipservicesk9-mz.124-24.T3.bin" for NPEG2 in Cisco FN? Because for NPEG2 Cisco FN will only list "c7200p-advipservicesk9-mz.124-24.T3.bin ". IOS of NPEG2 starts with "c7200p" for NPEG1 starts with "c7200". You can check the IOS for NPEG2 using cisco.com/go/fn.
HTH...
thanks
Arun
07-15-2010 02:51 PM
The difference between the two images is which NPE they are for. The NPE-G2 uses a PowerPC based CPU and requires the c7200p prefix. All other NPEs at this time use MIPS based processors. The same answer is also documented here:
http://tools.cisco.com/squish/D2c4E
11-07-2016 10:39 PM
Check it out
http://www.cisco.com/c/en/us/td/docs/ios/12_4/12_4x/release/notes/rn7000XD.html
Warning Unlike other network processing engines, the Cisco NPE-G2 has its own Cisco IOS software images with the prefix of "c7200p-" in the software image file names. All other network processing engines such as NPE-225, NPE-400 and NPE-G1 are compatible with images with the prefix of "c7200-." The Cisco NPE-G2 does not boot up with a software image with the prefix of "c7200-". Conversely, the other network processing engines such as NPE-225, NPE-400, and NPE-G1 do not boot up with the software image with the prefix of "c7200p-".
