any other options for load balancing
Jun 28th, 2010
hello everyone,
i have been unsuccessful to implement load balancing effectively. have you come across any such problems with load balancing not working as expected? are there any othner options to implement load balancing?
thank you in advance
abersven Mon, 06/28/2010 - 13:39
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I do not see what you want to achieve or what you have tried to do. So please provide some more information.
/André
solomon2000 Tue, 06/29/2010 - 06:37
hi Andre,
I have a test lab. The controller is cisco4402, wcs software is the latest one, i think 6.9. we have a mix of light weight converted APs. the APs are working fine. I want to be able to limit the number of clients onto an access point. Say 10 per AP and effectively block any further client association. I have not been successful at all.
Any help will be highly appreciated
