vpn hardware error with packets bigger than 128 Byte payload
Jun 28th, 2010
anyone else having the same problem?
000085: Jun 21 18:09:12.635 CEST: %VPN_HW-1-PACKET_ERROR: slot: 0 Packet Encryption/Decryption error, Invalid Packet:srcadr=192.168.x.x,dstadr=172.x.x.x,size=120,handle=0x5801.....
Success rate is 0 percent (0/5)
legacy vpn
crypto map
transform-set esp-sha1 esp-aes-128
(hub)
2811 with aim-module AIM-VPN/EPII-PLUS
c2800nm-advipservicesk9-mz.124-8c.bin
c2800nm-advipservicesk9-mz.124-25c.bin
(spoke)
c1841-advipservicesk9-mz.124-10c.bin
on-board-vpn-chip
small packet passes
bigger packets hangs
Don't think of fragmentation, because we are still below the 576-size!
any hint is appreciated, William
Marcin Latosiewicz Mon, 06/28/2010 - 06:38
William,
Please check if the problem persists with onboard accelarator.
I would be interested in:
"show crypt eli"
"show crypto engine accel stati"
Marcin
edit:
Ad, changing accelarator - please note that it will most likely need to re-establish the tunnels.
9w.boye Mon, 06/28/2010 - 07:42
changing from hardware-module to onboard to software ipsec brought no success
no crypto engine aim
no crypto engine onboard
with aim-module:
Show crypto engine accelerator stat
xxx#show crypto engine acc stat
Virtual Private Network (VPN) Module in slot : 0
Statistics for Hardware VPN Module since the last clear
of counters 285502 seconds ago
Errors:
ppq full errors : 0 ppq rx errors : 33
NR overflow : 0 pkts dropped : 33
Warnings:
sessions_expired : 0 packets_fragmented : 0
general: : 0
HSP details:
hsp_operations : 66775 hsp_sessions : 4
xxxx#ping 172.16.9.240 source loop0 size 200 repeat 1
Sending 1, 200-byte ICMP Echos to 172.16.9.240, timeout is 2 seconds:
Packet sent with a source address of x.x.x.x
000112: Jun 21 18:25:26.962 CEST: %VPN_HW-1-PACKET_ERROR: slot: 0 Packet Encryption/Decryption error, Invalid Packet:srcadr=192.168.x.x,dstadr=172.x.x.x size=120,handle=0x5801.
Success rate is 0 percent (0/1)
r-zhza1#show crypto engine acc stat
of counters 285543 seconds ago
Errors:
ppq full errors : 0 ppq rx errors : 34
Decrypt Failure : 0 Invalid Packet : 34
NR overflow : 0 pkts dropped : 34
Warnings:
general: : 0
Marcin Latosiewicz Mon, 06/28/2010 - 08:27
Did you check that you changed crypto from AIM to software "show crypto ipsec sa | i flow" will tell you.
IF the problem persists on soft and hard crypto then it's time to check:
1) Other side - punt in from software to hardwar (or vice versa) - does it change anything?
2) ISP? Check capture on one side as compared to other side. (I would suggest SPAN if possible)
9w.boye Mon, 06/28/2010 - 09:12
Hello Marcin, I appreciate your efforts very much. But don't you think it is time for an internal answer?
After the first occurences - with the 25c-image on the hub - we made a test inside of our lab: with the same result.
Our second router had a bit older image: 8c. So we thought this might be the cause.
It turned out, that it was not.
What else was different? On the "working" hub-side we used as the transform-set esp-aes-256 AND comp-lzs
We wanted to change it - what makes sense - to esp-aes-128 and esp-sha1
Of course we cleared the crypto sas on both sides.
And if I see a hardware vpn error, severity 1, I am getting a bit courious: ping with size 99 works, ping with size 100 not.
Any ideas?
William
Marcin Latosiewicz Mon, 06/28/2010 - 10:20
William,
What would you exactly call "internal answer"?
This error appears mostly in case of those:
- Something mangling packet on the way (get capture on both end on physical interfaces)
- HW error - not likely since issue persist with and without HW encryption
- Misconfig/mismatch/not-supported config
- bug - not very likely.
That's why it was curious for me what happens with different encryption setting on both sides.
Marcin
9w.boye Mon, 06/28/2010 - 11:17
Hm, okay
what would be mangling in the way in my testlab?
ok, if not hardware, then software?
well, why is it working with the other transform-set?
not very likely?
In one forum answer on such kind of issue, I found the answer to turn out cef and fast-switching ...
William
Marcin Latosiewicz Mon, 06/28/2010 - 11:53
Ah that's the info I missed.
Which transform sets work and which ones do not?
If you suspect a bug in CEF, disable it ... it's a test lab after all...
9w.boye Tue, 06/29/2010 - 00:16
There are enough infos on the table.
Hardware 1 error, internal information: handle= ...
accelerator output - what is the reason for the drop of this packets
anyone else with experiences or more information about possible incompatibilities between the mentioned devices/software?
turning off cef is a joke. I don't have a aim-module on one hand to process-switch on the outer interface.
William
Marcin Latosiewicz Tue, 06/29/2010 - 02:39
William,
If turning of CEF would help you would see different behavior when pinging FROM the device itself and through.
Which table are you refering to?
Marcin
