06-28-2010 06:17 AM - edited 03-14-2019 05:57 AM
Hello All,
I am changing the MOH file in my telephony environment ( CUCMBE 7.1.3, UCCX 7.0) and just had a quick question regarding MOH files. Once I add the new MOH file to CM and make it available to all of the phones is there anything I need to do on the UCCX side? Just resync maybe? Just curious.
Any info would be great.
Jeff
Solved! Go to Solution.
06-28-2010 08:47 AM
Hello Jeff,
At the UCCX side you don't need to perform any change as long as the agents has access to the proper MRG no changes needs to be perform.
Please rate this post if was helpful
Walter Solano
CCVP, Cisco UCCX Specialist
Cisco IP Communications Express Specialist
06-28-2010 08:47 AM
Hello Jeff,
Walter Solano
06-28-2010 11:21 AM
So, since they are using the current CDC and have access to the MRG, simply changing something within that would require nothing to be done on the UCCX side?
Just want to make sure before I make this change.
Jeff
06-28-2010 11:25 AM
You are right, nothing at the UCCX side.
Walter Solano
