incoming calls ring to a dial tone
Jun 28th, 2010
uc 560
incomming calls to DID's ring to a dail tone
dial-peer voice 150 pots
  incoming called-number .T
any ideas?
Overall Rating: 5 (1 ratings)
Brandon Buffin Mon, 06/28/2010 - 06:50
What type of PSTN connection? PRI, POTS? If POTS, add the following to the voice port config:
voice-port 0/0/0
connection plar 100 (This will be the DN that you want incoming calls to ring to)
Hope this helps.
Brandon Buffin Mon, 06/28/2010 - 06:59
Try changing the command to "incoming called-number ."
You can also run "debug voip dialpeer" to make sure that this dial peer is being matched on an incoming call.
Abu Hadee Mon, 06/28/2010 - 07:00
do you have any other pots dial-peer?
try "debug voip ccapi inout" to find which incoming dial-peer it is matching.
- abu
Walter Solano Mon, 06/28/2010 - 08:42
Hello Michael.
Please try to change the "incoming called-number .t" to "incoming called-number .", another think that could be causing this issue its another dial-peer has been match as an incoming dial-peer please run a "debug voip CCAPI" when the call its coming into the system that will let us know which one its the true incoming dial-peer.
Please rate this post if was helpful
Walter Solano
CCVP, Cisco UCCX Specialist
Cisco IP Communications Express Specialist
