Help load balancing a router
Jun 28th, 2010
Our Internet router is a 2800 and has 2 fast ethernet ports and 2 serial ports.  However only one of our Cisco switches has a route to it, what would we need to do to link the other Cisco switch to it as this will give us some redundacy?
danrya Mon, 06/28/2010 - 06:38
  • Bronze, 100 points or more
Some additional info would be helpful. Are you using static routes?  Are the stacks Layer-2 or Layer-3?  Are you running HSRP (or any next-hop redundency)? Is the Internet connection on one of the FastE's or on a serial port?  Do you have any free ports on the second core?
Dan
Andy White Mon, 06/28/2010 - 06:48
Yeah sorry about that, they are L3 3750 switches.  No HSRP on the router.  The internet is serial so I have 1 free FE.  The second core has lots of free ports.  We use EIGRP.
Many thanks
