abhishekbanik Mon, 06/28/2010 - 08:13
Hi Rob,
.Thanks for the reply, iam try to do bulk adminitration of UDP with 2 extension added in single UDP. Can it be possible.to do so.
For eg we will given single phones to the 2 user which will have there own extension added on that phone.
Abhishek
Aaron Harrison Tue, 06/29/2010 - 01:15
  • Community Spotlight Award,
    Member's Choice, May 2015
What are you trying to do in Bulk Admin? Modify existing? Add new?
If you are adding new UDPs, then you would need to do two things:
1) In the BAT spreadsheet, on the User Device Profile page, set 'Maximum Number of Lines' to 2 (on the far right of the worksheet)
2) In CCM, make sure you create a User Device Profile template under the BAT menu that includes a Phone Button Template with two Lines assigned, or specify that Phone Button Template in the BAT spreadsheet.
Aaron
Please rate helpful posts...
