I converted Pix 501 Config to ASA 5505 but internet does not work
Jun 28th, 2010
I managed to convert our old Pix config to our new ASA 5505 config, but when i take out our PIX firewall, and put in the new ASA, internet does not work. Can you please see what i done wrong? I am not an expert so please if you have a solution, be very detailed. TYIA!
Here is the pix config:
PIX Version 6.3(5)
interface ethernet0 10baset
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password GWrHuOdSnP3vVpxD encrypted
passwd GWrHuOdSnP3vVpxD encrypted
hostname pixfirewall
domain-name xxxxxxxxxx.org
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list aclin permit tcp any host xx.x.xx.218 eq 4899
access-list aclin permit tcp any host xx.x.xx.218 eq smtp
access-list aclin permit tcp any host xx.x.xx.218 eq www
access-list aclin permit tcp any host xx.x.xx.218 eq citrix-ica
access-list aclin permit tcp host xx.x.xx.xx host xx.x.xx.218 eq ldap
access-list aclin permit tcp any host xx.x.xx.220 eq 3389
access-list vpn_nat_acl permit ip 172.16.1.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list outside_cryptomap_dyn_20 permit ip any 192.168.200.0 255.255.255.0
access-list jaremotes_splitTunnelAcl permit ip 172.16.1.0 255.255.255.0 any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside xx.x.xx.221 255.255.255.248
ip address inside 172.16.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool RemoteVPNPool 192.168.200.1-192.168.200.254
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list vpn_nat_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) xx.x.xx.218 172.16.1.2 netmask 255.255.255.255 0 0
static (inside,outside) xx.x.xx.219 172.16.1.3 netmask 255.255.255.255 0 0
static (inside,outside) xx.x.xx.220 172.16.1.4 netmask 255.255.255.255 0 0
access-group aclin in interface outside
route outside 0.0.0.0 0.0.0.0 xx.x.xx.217 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
http 172.16.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt noproxyarp inside
crypto ipsec transform-set strong esp-des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set strong
crypto map toDayton 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map toDayton client configuration address initiate
crypto map toDayton client configuration address respond
crypto map toDayton interface outside
isakmp enable outside
isakmp key xxxxxxxxxxxx address 0.0.0.0 netmask 0.0.0.0
isakmp client configuration address-pool local RemoteVPNPool outside
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
isakmp policy 15 authentication pre-share
isakmp policy 15 encryption des
isakmp policy 15 hash md5
isakmp policy 15 group 2
isakmp policy 15 lifetime 86400
vpngroup jaremotes address-pool RemoteVPNPool
vpngroup jaremotes dns-server 172.16.1.2
vpngroup jaremotes default-domain xxxxxxxxxxx.ORG
vpngroup jaremotes split-tunnel jaremotes_splitTunnelAcl
vpngroup jaremotes idle-time 7200
vpngroup jaremotes password xxxxxxxxxxxxxx
telnet 172.16.1.0 255.255.255.0 inside
telnet timeout 5
ssh xx.x.xx.0 255.255.255.0 outside
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:a939584ebafeaba60b199056eb90789a
: end
and here is the new ASA 5505 config:
ASA Config
ASA Version 7.2(4)
domain-name jaxxxxxxxx.org
names
interface Vlan1
nameif inside
security-level 100
ip address 172.16.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xx.x.xx.221 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
domain-name jaxxxxxxxs.org
access-list aclin extended permit tcp any host xx.x.xx.218 eq 4899
access-list aclin extended permit tcp any host xx.x.xx.218 eq smtp
access-list aclin extended permit tcp any host xx.x.xx.218 eq www
access-list aclin extended permit tcp any host xx.x.xx.218 eq citrix-ica
access-list aclin extended permit tcp host 69.x.xx.23 host xx.x.xx.218 eq ldap
access-list aclin extended permit tcp any host xx.x.xx.220 eq 3389
access-list vpn_nat_acl extended permit ip 172.16.1.0 255.255.255.0 192.168.200.
0 255.255.255.0
access-list outside_cryptomap_dyn_20 extended permit ip any 192.168.200.0 255.25
5.255.0
access-list jaremotes_splitTunnelAcl extended permit ip 172.16.1.0 255.255.255.0
any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
asdm history enable
arp timeout 14400
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto isakmp enable outside
crypto isakmp policy 10
encryption des
hash md5
group 1
lifetime 86400
crypto isakmp policy 15
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp nat-traversal  20
telnet timeout 5
ssh xx.x.70.0 255.255.255.0 outside
ssh timeout 5
console timeout 0
group-policy jaremotes internal
group-policy jaremotes attributes
dns-server value 172.16.1.2
vpn-idle-timeout 120
split-tunnel-policy tunnelspecified
split-tunnel-network-list value jaremotes_splitTunnelAcl
default-domain value JASxxxxx.ORG
tunnel-group DefaultRAGroup general-attributes
address-pool (outside) RemoteVPNPool
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
tunnel-group jaremotes type ipsec-ra
tunnel-group jaremotes general-attributes
default-group-policy jaremotes
tunnel-group jaremotes ipsec-attributes
pre-shared-key *
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
service-policy global_policy global
prompt hostname context
Cryptochecksum:3f5981080b7be5619f2b3ac81168202f
: end
Cryptochecksum:d88c038c3d1a8da0ac01ee9c767bd851
: end
acomiskey Mon, 06/28/2010 - 06:21
  • Green, 3000 points or more
The outside ip address on the ASA is different than the one on your pix.
brigikovacs Mon, 06/28/2010 - 06:46
Sorry i noticed i posted the wrong config - i just updated it. Any ideas now? thanks
kangupta Mon, 06/28/2010 - 08:53
  • Cisco Employee,
Hi, make sure to clear the arp cache on the upstream device (x.x.x.217) after replacing the PIX with an ASA or simply reboot it.
Are you able to ping this device from your ASA?
brigikovacs Mon, 06/28/2010 - 09:06
i just restarted everything - still no internet  - i will report back on ping in  a while
brigikovacs Mon, 06/28/2010 - 09:52
pixfirewall# ping xx.x.xx.217
Sending 5, 100-byte ICMP Echos to xx.x.xx.217, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 10/12/20 ms
kangupta Mon, 06/28/2010 - 11:31
  • Cisco Employee,
You will need to check the logs and packet captures on the ASA to see if it is receiving this traffic and if at all dropping any packets.
If you do not how to capture this information, please open a TAC case to investigate further.
Thanks.
Related Content
