split tunnel based on remote user location
Jun 28th, 2010
Good afternoon,
For remote vpn users, I would like to configure a dynamic vpn split tunnel depending where are they connected.
For example if a remote user is connected to ASA from italy, auth via acs radius server, a split tunnel list will be applied allowing user to access local resources, if the same user is connecting from germany, apply a split tunnel list allowing the local resources for germany office...
is it possible to achieve this? any link or documentation related?
Thanks for your support
Michael Dombek Thu, 07/01/2010 - 00:53
Hi their sure you can do this.
If your User conencts you have to assign him a dACL and Shared RAC based on the Network Access Profile and the NAF for your locations.
EG:
create a Network Access Filter for Germany with all your german ASAs one for Italy with all your italian ASAs etc.
create a "Germany" Shared RAC with the important german settings (DNS wins etc)
Create a "Italy" Shared RAC with the settings for Italy
create dACL (for each location)
then go and create a Network access Profile for germany and one for italy - apply the network filter and assign  under authorization the dACL and sRAC.
Should work without problems
Maybe have a look here:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.0/user/guide/sp.html
Cheers Michael
franpena2008 Thu, 07/01/2010 - 06:13
I am working with ACS appliance v 5.1 for radius authentication/authorization
All clients are connecting to the same central ASA.
I have found in ACS Policy Elements - End station filters - Where I think I can diffrentiate where are the clients located.
Anybody knows if end station filters refer to the clients network or to the asa?
Thnks and best regards
Fran
