Jun 28th, 2010
I am attempting to modify an existing tcl script that can apply QoS policies on IP Phones and Router/Switch ports but it does not seem to work, anyone know what I could be doing wrong? Ideally once I have this script working, I would use EEM netconfig job in LMS 3.2 to a group of switches. I have attached the script to this discussion.
Best regards,
Joe Clarke Mon, 06/28/2010 - 23:13
Exactly what are you doing, and what errors are you seeing?  On what version of IOS are you installing this policy?
Jaffer.Razvi Tue, 06/29/2010 - 06:30
I am trying to do the following:
Apply "auto qos voip cisco-phone" on IP Phones
Apply "auto qos voip trust" on ports connected to other switches and routers
Running the following version:
12.2(53) IP Services
QoS policies don't seem to apply ports connected switches and routers.
Joe Clarke Thu, 07/01/2010 - 11:35
What errors are you seeing in the show log from the switch?  Are you using AAA command authorization on this device?
Jaffer.Razvi Thu, 07/01/2010 - 14:33
There are no errors. I am not using AAA, just local authentication. The EEM job through RME deploys just fine:
mkdir  flash:/QoS
event  manager directory user policy flash:/QoS
copy  t flash:/QoS/QoS.tcl
event  manager policy QoS.tcl
But the policy does not seem to be doing anything, its connected to another switch but its not applying the QoS policy to uplink port.
show event manager policy registered
No.  Class     Type    Event Type          Trap  Time Registered           Secu
1    script    user    syslog              Off   Fri May 7 10:11:05 1993   2048
pattern {%LINK-3-UPDOWN}
nice 0 queue-priority normal maxrun 60.000 scheduler rp_primary
Joe Clarke Thu, 07/01/2010 - 14:36
Enable "debug event manager tcl cli", trigger the policy again, then post the debug output.
Jaffer.Razvi Thu, 07/01/2010 - 14:54
Seems the policy only triggers when an interface goes up and down, it doesn't trigger if the interface is already up. The script seems to be incorrect from the looks of it.
Jaffer.Razvi Fri, 07/02/2010 - 13:53
Niiice but the QoS policy worked to the policy after I physically disconnect/reconnect the port connected to another switch, is there a way to apply the policy if its already connected?
Joe Clarke Fri, 07/02/2010 - 22:47
How would you want to trigger it if the interface is already up?  Does this need to be timer-based, or does it need to run manually?
Jaffer.Razvi Sat, 07/03/2010 - 12:31
Yes, if its already up and if a new interfaces comes up (IP Phone, Router, Switch) to apply the correct QoS statements, would that be possible?
Joe Clarke Sun, 07/04/2010 - 23:27
Again, what do you want the trigger to be?  The way the policy is written now, when ANY interface comes up, your QoS commands will be applied to that interface.  The trigger for this is a syslog message.  Do you want another trigger, and if so, what trigger do you want?
Jaffer.Razvi Mon, 07/05/2010 - 18:00
I think my only requirement is that it should apply the policy according to the device type, I don't want to reset the physical interface just to apply the QoS policy. If the interface is already up than I suppose there would not be any messages via syslog hence no trigger, what else would you recommend?
Joe Clarke Tue, 07/06/2010 - 22:49
Try this version.  This version will either react to a link up syslog message or a manual execution.  If you run the command as:
event manager run QoS.tcl
Then the script will process the device connected to .   For example:
event manager run QoS.tcl FastEthernet0/1
Related Content
