ASA 5505 vpnclient command with L2L to another location
Jun 28th, 2010
I have a situation where we have a L2L vpn already setup. We need to tie into a 3rd party vendor and they support the vpnclient option from the ASA. They do this so they don't have to deal overlapping networks from us and other customers. All is fine until you try to use vpnclient command when a L2L is already defined. Anybody have a good way around this? Vendor won't adjust there side.....
Thx
Federico Coto F... Mon, 06/28/2010 - 16:04
I know that if you configure an ASA as an EzVPN client, it cannot be an EzVPN server simultaneosuly. I'm not sure if the same rule applied for L2L tunnels.
In other words, if you were to configure the ASA with the ''vpnclient'' command therefore using it as an EzVPN client, then it can only be a client and not a server.
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/ezvpn505.html
Federico.
