Question about NAT, cannot reach other subnet..
Jun 28th, 2010
Hello guys.
I have an asa5505 router 1
Interface1 (OUT) 199.255.23.23
Interface2(Inside) 192.168.0.1
I have another router, (router2), that routes to another subnet (subnet 192.168.2.x), it's inside IP is 192.168.0.2
Clients inside of 192.168.0.x have router 1 inside as gateway,
I created fw rules any any Ip and a route: inside 192.168.2.0 255.255.255.0 192.168.0.2
When I do a packet trace it blocks at NAT.
The only dynamic rule I have is  any to OUTSIDE IP, which permits me to access intenet..
What nat rule should I do to be able to access 192.168.2.x from the 192.168.0.x client netwrok (im currently able to ping hosts in 192.168.2.x from the router, but not clients, like i said it blocks at nat rule.
djh278778 Mon, 06/28/2010 - 13:14
It sounds like you need a  "nat 0" statement. For example:
Create an ACL that permits 192.168.0.x to 192.168.2.x and a second line that permits 192.168.2.x to 192.168.0.x
Then create a NAT statement that would look like this: "nat (inside) 0 access-list xxx (xxx being the name of your ACL).
Nat 0 says "dont do nat for the given subnets".
I am of course speculating not having more details. If you dont think this is the resolution, post a config of the ASA and more details on your topology.
d.calinescu Mon, 06/28/2010 - 13:29
I will give this a try tonight and if it doesnt work I'll be as detailed as possible and paste the config.
Thanks!
Dan
