Separating Active/Failover pair ...ASA5520
fsebera
Level 4
Level 4
We have two ASA5520 firewalls configured as active/failover, both firewalls are identical in hardware and software. Currently this are NO issues with this setup.
We want to separate these two firewalls and use each as an active ASA5520 firewall independent from the other. I.E. No failover option.
As I read through the Cisco Security Appliance CLI guide, I see there are many issue with setting the two devices into Active/Failover mode but not seeing anything on separating them.
Anyone have experience performing this task and things to look out for, licensing issues, etc.?
Thank you
Frank
So you want to disable the Active failover and put them to work in different Environments?
If that's so, there is not any problem.
