Rob Huffman Mon, 06/28/2010 - 11:08
Hi there,
Here is the path
Voice and Unified Communications  > Unified Communications Applications > Voice Mail and Unified Messaging > Cisco Unity Express Version 7.0  > Unity Express License Packages  > 7.0.3 > cue-vm-license_12mbx_ccm_7.0.3.pkg
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Daniel Azuara Torres Mon, 06/28/2010 - 11:16
thanks rob but I'm looking for specifically for 1861 ISE module, in the part that you say me there is valid license file for ISE module.
Rob Huffman Mon, 06/28/2010 - 12:06
Hi there,
Sorry about that, it would help if I could read
Are you sure about that Part# I don't believe that it exists
and that is why you are having trouble finding it for Download. I don't
think these License upgrade/addition files will be supported on the 1861 ISE.
Cheers!
Rob
