Switch security Audit
Jun 28th, 2010
Years ago I used SDM to run a “wizard” that would perform a security audit on routers and switches and give you the steps to remediate them. I am looking for something similar now. I see I can use Cisco Configuration Professional for the routers but I can’t find a tool for a switch security audit. Any recommendations? Thanks.
Ganesh Hariharan Tue, 06/29/2010 - 01:14
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
If you want to know the vulnerbilty and holes in network devices use one of the open standard tools like Nipper is a much better tool.It Supports multiple
vendors such as Juniper and Checkpoint.
Use these two links as references for hardening and secure ios features
Secure IOS template
http://www.cymru.com/Documents/secure-ios-template.html
Cisco Guide to Harden Cisco IOS Devices
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080120f48.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Bill19795_2 Fri, 07/16/2010 - 15:19
Nipper is now commercial. Are there any open source tools that are current to do the configuration audit?
Ganesh Hariharan Sat, 07/17/2010 - 01:36
Try with Nessus® vulnerability scannerfor configuration audit.
Hope to Help !!
Ganesh.H
