UCCX Phones Ringing Once
Jun 28th, 2010
Encountered a situation where CCX phones are ringing only once.  It is random and I have not been able to duplicate.  Anyone have anythoughts?  It is only being reported on Contact Center phones.  CM 7.1.3b , UCCX 7.0 environment.
Aaron Harrison Tue, 06/29/2010 - 00:42
It's possible the external caller is hanging up..
1) Get the agents to log the calling number and time of the call when it happens (getting CLI from their call log report in CAD).
2) In CCM, have detailed tracing enabled - drop the logs into triplecombo and see whether the ISDN disconnect originates from CCM, or from the PSTN.
Please rate helpful posts..
Jonathan Schulenberg Tue, 06/29/2010 - 07:36
Also make sure that your exact versions of CCX and UCM are listed as compatible. Small version changes in one product or the other that are not explicitly listed in the compatibility matrix has resulted in odd JTAPI behavior such as this in the past.
jeffrey-young Tue, 06/29/2010 - 09:03
I am using:
UCCX v. 7.0(1)SR05_Build504
I have consuleted the compatability matrix
PG. 51ish shows that they are compatable.
Thanks for the suggestions.  The issue is really random thus making it pretty difficult to troubleshoot, guess I just need to sit and wait until it happens again to grab the logs.
