EEM, traceroute
Answered Question
Jun 28th, 2010
I'm using EEM to check the results of traceroutes and in the event I do not see an IP range in the traceroute results, I take a particular action. I am able to specify a particular address in set hop_found(192.168.108.153) and search for it. My issue is that I do not care about the last 2 octets of the IP address. Meaning, if I see the 192.168 as a next hop, I consider it a successful tracert. How can I specify only 192.168 to be searched for in the traceroute output.
Below is working code.
Correct Answer by Joe Clarke about 6 years 12 months ago
I think I understand that you just want to match the first two octets in a traceroute hop.  If that is the case, then this code should work for you.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 06/28/2010 - 23:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
mruhenkamp Tue, 06/29/2010 - 04:29
Joe,
Hey.....that's it. Exactly what I was looking for. I appreciate the help.
Mark
