6509 manual reload
Jun 28th, 2010
After manual reload appears this message:
*Jun 28 08:05:09.675: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jun 28 08:05:08.335: CM file (ivfs:/s72033_sp-advipservicesk9-m_matrix.cm) is not readable, using internal matrix table
*Jun 28 08:05:08.799: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
*Jun 28 08:05:08.839: %C6K_PLATFORM-4-DETECTED_NON_C7600_CHASSIS: Software has detected an attempt to run a c7600 image on an incompatible chassis WS-C6509 (36866)
*Jun 28 08:05:09.671: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
And the modules 1 and 8 turn down.
Can someone say me what is the possible cause?
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD0805022X
  3    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      JAF1212BRPG
  4    8  8 port 1000mb ethernet                 WS-X6408-GBIC      SAD041500KU
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     SAD0951035V
  6    2  Supervisor Engine 720 (Hot)            WS-SUP720-3BXL     SAD1208029X
  7    8  8 port 1000mb GBIC Enhanced QoS        WS-X6408A-GBIC     SAL0506310M
  8   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAD091503B5
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  000e.83ea.c0d4 to 000e.83ea.c103   1.4   12.2(14r)S5  12.2(33)SRD  Ok
  3  001f.6cad.8490 to 001f.6cad.8493   2.7   12.2(14r)S5  12.2(33)SRD  Ok
  4  00d0.d3a0.d89c to 00d0.d3a0.d8a3   2.4   5.1(1)CSX    8.7(0.22)FW2 Ok
  5  0011.5cab.80bc to 0011.5cab.80bf   4.3   8.1(3)       12.2(33)SRD  Ok
  6  0013.807b.9ed0 to 0013.807b.9ed3   5.6   8.5(2)       12.2(33)SRD  Ok
  7  0001.9724.0c14 to 0001.9724.0c1b   1.3   5.4(2)       8.7(0.22)FW2 Ok
  8  0012.0059.a4a4 to 0012.0059.a4bb   2.2   12.2(14r)S5  12.2(33)SRD  Ok
------------------ show version ------------------
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRD, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 24-Oct-08 02:34 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
R6500 uptime is 9 weeks, 6 days, 19 hours, 43 minutes
Uptime for this control processor is 9 weeks, 6 days, 19 hours, 38 minutes
System returned to ROM by  power cycle (SP by power on)
System restarted at 10:25:45 BSAS Wed Apr 14 2010
System image file is "disk0:s72033-advipservicesk9-mz.122-33.SRD.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509 (R7000) processor (revision 2.0) with 983008K/65536K bytes of memory.
Processor board ID SCA050702WY
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
27 Virtual Ethernet interfaces
92 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Jerry Ye Mon, 06/28/2010 - 12:44
  • Cisco Employee,
As the following message describe
You are using the C7600 software (SRx train) on a C6500 hardware. This is not a support solution, and you should use the C6500 software instead (SXx).
jerry
