NAT'ing Kills ICMP Traffic
Jun 28th, 2010
packet-tracer shows ping traffic being dropped at NAT phase 7 and Result states "Drop-reason: (acl-drop) Flow is denied by configured rule"
firewall has simple configuration:
access-list Inside_access_in permit tcp object "source" object-group "destination" object-group "service-ports"
access-list Inside_access_in permit icmp object "source" object-group "destination"
icmp permit "source/-inside LAN" Inside
object network "source object-group network"
nat (any,destination) dynamic interface
access-group Inside_access_in in interface Inside
route "destination and mask" "gateway IP"
there are no ACLs being used on the outside interface, no assigned access-group
packet-tracer shows all other port of traffic (in service-port object-group) being permitted through firewall's NAT policy.  only icmp is being dropped.
any suggestions would be appreicated.
Diego Armando C... Mon, 06/28/2010 - 14:06
Do you have the inspeccion for icmp ON??
Go ahead and inspect icmp traffi. Post the config as well it will make easier to find the issue.
Diego Armando C... Mon, 06/28/2010 - 14:47
I'm seeing in ur config that u do not have a global statement for the nat
try this to nat your inside LAN to the ip address on your US_X  Interface
nat (inside) 1
gloabal (US_x) 1 interface
also to know that is happeing let take a capture.
access-list capture permit icmp any any
capture capin access-list capture inteface inside
capture capout access-list capture inteface US_X
try to ping the IP address in the internet and then send me the show cap capin   and the show cap capout
Diego Armando C... Mon, 06/28/2010 - 14:49
Sorry I didn't notice that you are using version 8.3  your config is right.. go ahead and take the capture ONLY
KSVY_KSVY_2 Mon, 06/28/2010 - 14:53
yeap, that's what I am suggesting, a basic static global NAT policy... but currently waiting for management to approve.  I will follow up with you.
Diego Armando C... Mon, 06/28/2010 - 14:55
I do not see this in ur config
object network obj-10.100.x.150
subnet 10.100.x.150
nat (inside,US_X) dynamic interface
you have this
object network x-NET
nat (any,US_x) dynamic interface
you are not specifying the network to nat
KSVY_KSVY_2 Mon, 06/28/2010 - 15:15
subnet 10.100.x.150
are the asa's inside interface: ip address standby
nat (inside,US_x) dynamic interface
i guess, is being assigned as
nat (any, US_x) dynamic interface
packet-tracer show all other traffic being permitted, which shows:
Phase: 7
Type: NAT
Result: ALLOW
Additional Information:
Dynamic translate to 65.x.121.125/54546
the source network is object-group x-NET  which is
