Showing results forĀ
Search instead forĀ
Did you mean:Ā
SSL Termination not working in ACE
krishnadas.R_2
The context was configured for Load Balancing Port 80 and 443 traffic before the SSL Configs was Applied.
The SSL Termination is configured on ACE module running the software version  A2(1.6a) [build 3.0(0)A2(1.6a)
The load balacing is working without no issues, But when i do a https://abc.www.abc.qa/wps/portal/login
the browser reconganizes the certificate from ACE, but does not show up any thing, just shows  this symbol ā‚¬
in a blank page.
Plese let me know if you have any suggestions.
Thanks in Advance.
Here is the relevant config.
crypto csr-params ABC-II-PRAMS
  country XX
  state XXXX
  locality XXXX
  organization-name abc council
  common-name abc.www.abc.qa
  serial-number 1
  email abc@abc.com
rserver host abcserver1
  ip address 10.14.1.165
  inservice
rserver host abcserver2
  ip address 10.14.1.177
  inservice
ssl-proxy service abc.www.proxy
  key abc-II-key.pem
  cert abc-II-cert.pem
serverfarm host abc.www.abc.qa-443
  failaction purge
  rserver abcserver1
    probe abcicmp
    inservice
  rserver abcserver2
    probe abcicmp
    inservice
serverfarm host abc.www.abc.qa-80
  failaction purge
  rserver abcserver1
    probe abcicmp
    inservice
  rserver abcserver2
    probe abcicmp
    inservice
sticky ip-netmask 255.255.255.255 address source abc.www.abc.qa-sticky-80
timeout 120
serverfarm abc.www.abc.qa-80
sticky ip-netmask 255.255.255.255 address source abc.www.abc.qa-sticky-443
timeout 120
serverfarm abc.www.abc.qa-443
class-map match-all abc.www.abc.qa-443
match virtual-address 10.14.1.203 tcp eq https
class-map match-all abc.www.abc.qa-80
match virtual-address 10.14.1.203 tcp eq www
policy-map type loadbalance first-match abc.www.abc.qa-VIP-443
class class-default
sticky-serverfarm abc.www.abc.qa-sticky-443
policy-map type loadbalance first-match abc.www.abc.qa-VIP-80
class class-default
sticky-serverfarm abc.www.abc.qa-sticky-80
policy-map multi-match abc-POLICY
class abc.www.abc.qa-80
    loadbalance vip inservice
    loadbalance policy abc.www.abc.qa-VIP-80
    loadbalance vip icmp-reply
  class abc.www.abc.qa-443
    loadbalance policy abc.www.abc.qa-VIP-443
    ssl-proxy server abc.www.proxy
Pablo
You may want to check this thread I think it would be very helpful.
https://supportforums.cisco.com/thread/2027253
__ __
Pablo
Cisco TAC
Pablo
__ __
Pablo
Cisco TAC
It is working now, adding port 80 fixed  the issue.
Many Thanks.  5/5
