Having troubles configuring an 1841 Router.
Jun 28th, 2010
I'm trying to wrap my head around configuring an 1841 router.   I've cobbled this configuration together from various sources but I'm missing something, and I'm not able to see it.    Can someone please point out the incorrect areas in the config.
I have the following issues;
- The internal network doesn't reach the internet.
- The VPN connects fine but nothing is pingable from the client.
Jimi
version 12.4
no service pad
hostname cte-router
boot-start-marker
boot-end-marker
memory-size iomem 5
enable secret 5 $1$K.C2$wJc8lfV3r9dpYj4jpfw.m1
enable password xxxxxxxxxxx
username xxxxxx privilege 15 secret 5 $1$QfHe$02IRc2GShVwUorwXxfsKx1
username xxx privilege 15 secret 5 $1$7IvD$weP2PhOrUyPYKZHSPEKju0
aaa new-model
aaa authentication login cteuser local
aaa authorization network ctegroup local
aaa session-id common
ip subnet-zero
no ip routing
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.150 192.168.1.254
ip dhcp pool cte-pool
   import all
   network 192.168.1.0 255.255.255.0
   dns-server 192.168.1.5 192.168.1.10
   default-router 192.168.1.254
   netbios-name-server 192.168.1.5 192.168.1.10
   lease 6
ip audit po max-events 100
no ftp-server write-enable
crypto isakmp policy 3
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group CTE
key vpnaccess234
dns 192.168.1.10 192.168.1.5
wins 192.168.1.10
pool VPN_Pool
include-local-lan
max-users 10
crypto ipsec transform-set vpnset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set vpnset
reverse-route
crypto map clientmap client authentication list cteuser
crypto map clientmap isakmp authorization list ctegroup
crypto map clientmap client configuration address initiate
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Loopback0
ip address 192.168.3.1 255.255.255.0
ip nat inside
interface FastEthernet0
description $FW_OUTSIDE$$ETH-WAN$
mac-address 0019.e4ae.9248
ip address dhcp client-id FastEthernet0 hostname cte-rt1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
ip policy route-map VPN-Client
interface FastEthernet1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
interface Virtual-Template1 type tunnel
ip unnumbered Vlan1
tunnel mode ipsec ipv4
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE2$$FW_INSIDE$
ip address 192.168.1.254 255.255.255.0
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
ip local pool VPN_Pool 192.168.2.100 192.168.2.110
ip classless
ip route 192.168.0.0 255.255.255.0 FastEthernet0
ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet0 overload
ip nat inside source static tcp 192.168.1.10 143 interface FastEthernet0 143
ip nat inside source static tcp 192.168.1.10 80 interface FastEthernet0 80
ip nat inside source static tcp 192.168.1.5 3390 interface FastEthernet0 3390
ip nat inside source static tcp 192.168.1.10 3389 interface FastEthernet0 3389
access-list 101 deny   ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
access-list 144 permit ip 192.168.2.0 0.0.0.255 any
route-map VPN-Client permit 10
match ip address 144
set ip next-hop 192.168.3.2
control-plane
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
password xxxxxxxxx
transport input all
scheduler max-task-time 5000
end
Chetan Kumar Ress Mon, 06/28/2010 - 14:54
  • Silver, 250 points or more
1]----- The VPN connects fine but nothing is pingable from the client.
You don't have any layer three interface on this router.
Here you should use the ip of the Pool that you define. i.e 192.168.2.1
interface Loopback1
ip address 192.168.2.1 255.255.255.0
2] The internal network doesn't reach the internet.
Use default route 0.0.0.0 0.0.0.0 Fa0
Chetan kumar
spremkumar Tue, 06/29/2010 - 03:03
  • Red, 2250 points or more
Configure a default route as mentioned by Chetan and try applying the below config.
no ip nat inside source list 101 interface FastEthernet0 overload
no route-map VPN-Client permit 10
no access-list 144
no access-list 101
ip nat inside source route-map nonat interface FastEthernet0 overload
route-map nonat permit 10
match ip address 101
regds
Related Content
