UCCX 7.0 back up and restore with a different hostname
Jun 28th, 2010
I need to rebuild an UCCX 7.0 due to "more than 15 characteres hostname" issue. So we will build it with a new hostname. Is it possible to restore a backup  which was done with a different computer name?
This system comes from an upgrade from  4.5 version to 7.0 and a lot of config had to be manually added and it should be done again if restoring does not work.
Thank you
Raul
Walter Solano Mon, 06/28/2010 - 15:10
Hi Raul,
Im so sorry to tell you that hostnames cannot be change during the restore, we can change the IP address but not the hostname.
Please rate this post if was helpful
Walter Solano
CCVP, Cisco UCCX Specialist
Cisco IP Communications Express Specialist
