Moving Historical Reports from UCCX 4.5 to 7.0
Jun 28th, 2010
Is it possible to import Historical reports in a UCCX 7.0 from a 4.0 Database?
We did an upgrade from version 4 to version 7, doing a fresh install and introducing the configuration manually ...
Thanks and regards
Anthony Holloway Mon, 06/28/2010 - 15:13
The only way to import Historical data is via an upgrade.  You performed a new build, so the answer is no.
I have heard rumors that certain partners developed a process to dig the data out, and insert it into the new server, but cannot speak from experience.
Maybe put some feelers out for that service.
