IAD2400 FXS issues
Jun 28th, 2010
I am fairly new to the IAD line of cisco devices so forgive me if my question is something obvious.  I recently purchased an old IAD2421-8FXS for use in my home lab and pretty much have it hadnling my analog handsets and connecting to my 1760v which hosts my IP phones running SCCP.  Calls from the IP phones across the local network to the IAD work great and so does the voice quality, however calls from the analog phones (connected to the FXS on the IAD) to the IP phones or to the PSTN (FXO card in the 1760v) are muffled and the voice breaks up.  I am wondering if this may be an attenuation issue or an input gain issues on the FXS ports, or do I just have a bad IAD unit.  Below is my IAD config.  Any help is appreciated.
-Jeff
version 12.3
no service pad
hostname fayrec-vgw-fxs
boot-start-marker
boot-end-marker
network-clock base-rate 56k
no aaa new-model
ip subnet-zero
ip name-server 192.168.0.1
ip audit po max-events 100
no voice confirmation-tone
voice-card 0
controller T1 0
framing esf
linecode b8zs
interface Ethernet0
ip address 192.168.0.203 255.255.255.0
interface Serial0
no ip address
shutdown
ip default-gateway 192.168.0.1
ip classless
no ip http server
voice-port 1/1
timing hookflash-in 1000
disc_pi_off
input gain 1
output attenuation 1
playout-delay minimum low
cptone HK
timing digit 53
description VOICE PORT 1 FXS
music-threshold -50
bearer-cap Speech
station-id name POTS
station-id number 2201
caller-id enable
disconnect-ack
voice-port 1/2
voice-port 1/3
voice-port 1/4
voice-port 1/5
voice-port 1/6
voice-port 1/7
voice-port 1/8
dial-peer voice 100 pots
description *** FXS PORT 1 ***
destination-pattern 2201
port 1/1
dial-peer voice 101 voip
description *** CONNECTION TO CISCO 1760V ****
translation-profile outgoing E164
destination-pattern 20..
session protocol sipv2
session target ipv4:192.168.0.201
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 102 voip
  description *** CONNECTION TO CISCO 1760V PSTN ****
  destination-pattern 9T
  dtmf-relay rtp-nte
  codec g711ulaw
line con 0
line aux 0
line 2 3
line vty 0 4
login
end
Related Content
