IP communicator setup
Jun 28th, 2010
I installed IP communicator 7.0.4 but Network configuration is disable in the preference.
It installed on windows 7
I need this to specify the tftp server.
thanks
philippe.cousineau Thu, 08/26/2010 - 07:05
Hi guys,
I have the same problem on my side even with the administrator.
Did you find anything to fix that ?
thanks !
philippe.cousineau Thu, 08/26/2010 - 08:11
I got It !!!
dont run it as a member from the administrators, it will not work.
Instead run it as THE administrator, this will let you modify the config.
Please rate if it help
j.morand Thu, 08/26/2010 - 08:18
I deleted all ipcommunicator item in the regedit
mlundbom1 Thu, 08/26/2010 - 11:09
Windows UAC, right-click the shortcut and "Run as administrator".
/M
