How to set enterprise WPA2 with the AP 1241 ( PEAP-MS-CHAP v2 )
Jun 29th, 2010
Hi friends
I've already set up the wpa2 with the WLC and AP 1130, with the IAS Radius server according to this howto:
http://cisco.com/en/US/products/ps6366/products_configuration_example09186a0080921f67.shtml
It's working without any problems
i'd like to do the same, but with the AP1241 ( autonomous ) without WLC.
I've tried to use this howto, but actualy it doesn't work :
http://cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml
The main question is if it's possible, because i don't know if the AP supports PEAP-MS-CHAP
When i use it,  IAS server says that the account is granted , but wireless connection on the client says :
Validaty cerificate eroor, or Potential problem with sup0plicant
Thanks for any hints
pet
Surendra BG Tue, 06/29/2010 - 01:47
  • Cisco Employee,
try by unchecking the "validate server certificate" or checking it.. if we are using the WZC.
peter_jevos Tue, 06/29/2010 - 05:23
I'm sorry ?
I cannot understand your answer properly ?
thanks
John Blakley Tue, 06/29/2010 - 11:16
  • Purple, 4500 points or more
On the client, under the wireless profile for this ssid, uncheck "validate server certificate." This option forces the Windows client to check with a third-party certificate provider (EnTrust and others) for YOUR certificate that you've applied to the server. You don't want this to happen, so you unselect "validate server certificate" and you won't get that error any longer.
HTH,
John
*Please rate all useful posts*
