Is it OK to put guest wireless through dmz port on my corporate firewall
Jun 29th, 2010
Hi all
I am implementing a guest wireless solution at my office, I have a cisco ASA, is it ok to plug my wireless lan controller into the DMZ in my company firewall?
Jennifer Halim Tue, 06/29/2010 - 04:19
I don't see why you can't connect the wireless controller to the firewall DMZ. However, just make sure that you only configure specific ACL to allow those guest network to access specific things that you would like them to access. I guess if you just want to provide internet access for them, I would configure ACL to deny access from the wireless subnet to anything towards your internal networks, and then allow the internet access.
carl_townshend Tue, 06/29/2010 - 07:31
Thanks for that
Where is it best to apply this access list? would I apply it outbound on the outside interface, allowing all traffic sourced from the dmz addresses? or do I apply it inbound into the dmz interface, add a deny statement first to any internal addresses, then allow dmz source to anywhere?
please help
Jennifer Halim Tue, 06/29/2010 - 15:00
I would recommend applying it inbound to the DMZ, as you have said earlier, denying all DMZ access to the internal networks, then allowing access to anything on the Internet. It would also be good if you can have the second lowest security level applied to this wireless DMZ connection. Assuming that your outside interface has security level of 0, then you would want to apply just a slightly better security level for DMZ (with DMZ security level being the lowest compared to all other internal network interfaces).
carl_townshend Tue, 06/29/2010 - 16:02
hi there
So is it OK to have my security level, 100 for inside, dmz 50, 0 for outside as standard ?
Federico Coto F... Tue, 06/29/2010 - 17:18
Normally the outside has a security level of 0, the inside of 100 and if having a single DMZ a security level of 50.
If having more DMZs, you can assign between (1-99)
Jennifer Halim Tue, 06/29/2010 - 18:05
yes, 50 sounds good to me.
As Federico said, if it's just a single DMZ, then you can use any number between 1-99.
