it's 7304 ios bug or hardware? The 7300-CC-PAhas returned to ROM Monitor
Jun 29th, 2010
Jun 16 22:39:00: %PACC-3-SYSRET: PA-CC in slot 4 has returned to ROM Monitor:
Reason: unknown reload cause - reason ptr 0xBFC20888, PC 0x601F88FC, address 0x0
Stack trace from system failure:
FP: 0x60CCB248, RA: 0x601F88FC
Jun 16 22:39:00: %LC-3-RECOVERY: Line card (slot 4) recovery in progress
-Traceback= 4072F64C 408FA94C 4090214C 401FF1C0 409007C4 40900C54 409012AC
Jun 21 20:54:40: %WSIPC-3-SYSCALL: System call for command 7 (port 4/0) : ipc_send_rpc_blocked timed-out (Cause: timeout)
-Traceback= 4072F64C 4096B960 4096BB14 4096BC68
Jun 21 20:55:02: %PACC-3-HEARTBEAT_LOSS: PA Carrier Card Loss of heartbeat from linecard in slot 4
Jun 21 20:55:02: %LC-3-RECOVERY: Line card (slot 4) recovery in progress
-Traceback= 4072F64C 408FA94C 4090214C 401FC9E0 40819D88 40736C08
Jun 27 09:08:14: %PACC-3-SYSRET: PA-CC in slot 4 has returned to ROM Monitor:
Reason: unknown reload cause - reason ptr 0xBFC20888, PC 0x601F2D28, address 0x0
FP: 0x60DEC2F8, RA: 0x601F2D28
FP: 0x60DEC430, RA: 0x601F2D20
Jun 27 09:08:14: %LC-3-RECOVERY: Line card (slot 4) recovery in progress
Jun 28 07:58:30: %PACC-3-HEARTBEAT_LOSS: PA Carrier Card Loss of heartbeat from linecard in slot 4
Jun 28 07:58:30: %LC-3-RECOVERY: Line card (slot 4) recovery in progress
look,the 7300-CC-PA has reload twice,so,what's the problem ? Thanks.online wait。
Brandon Lynch Tue, 06/29/2010 - 05:57
Can you collect a 'show tech' from this device and post it here?  Also, please include any crash files that may have been generated.  How long has this card been running in production on this box?  Have there been any recent hardware or configuration changes?
chinaxy11 Tue, 06/29/2010 - 18:55
First,thanks for you. here it is the "show tech" output,still,there have not been any recent hardware or configuration changes.this card been running in production on this box may be two or three years.
------------------ show version ------------------
Cisco IOS Software, 7300 Software (C7300-IS-M), Version 12.2(28)SB13, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 27-Jan-09 13:50 by pwade
ROM: System Bootstrap, Version 12.2(14r)SZ1, RELEASE SOFTWARE (fc1)
7304A uptime is 3 weeks, 4 days, 11 hours, 33 minutes
Uptime for this control processor is 3 weeks, 4 days, 11 hours, 33 minutes
System restarted at 22:59:11 BJ Thu Jun 3 2010
System image file is "disk0:c7300-is-mz.122-28.SB13.bin"
cisco 7300 (NPEG100) processor (revision B) with 983040K/65536K bytes of memory.
Processor board ID SMQ1021N393
SB-1 CPU at 800Mhz, Implementation 1025, Rev 0.2, 512KB L2 Cache
4 slot midplane, Version 67.49
Last reset from power-on
3 Gigabit Ethernet interfaces
228 Serial interfaces
4 Channelized STM-1 ports
1021K bytes of non-volatile configuration memory.
125440K bytes of ATA compact flash in bootdisk (Sector size 512 bytes).
250880K bytes of ATA compact flash in disk0 (Sector size 512 bytes).
------------------ show running-config ------------------
------------------ show stacks ------------------
Minimum process stacks:
Free/Size   Name
5712/6000   CDP BLOB
5704/6000   Probe Calibration
11488/12000  Router Init
8712/9000   cdp init process
8992/12000  Init
5416/6000   RADIUS INITCONFIG
2256/3000   Rom Random Update Process
34752/36000  TCP Command
6792/12000  Virtual Exec
9152/12000  Exec
Interrupt level stacks:
Level    Called Unused/Size  Name
  1   418992816   7120/9000  Network I/O
  3        9992   8536/9000  DMA/Timer Interrupt
  4       26578   8488/9000  Console Uart
  5        9649   7544/9000  OIR/Error Interrupt
  7   550401958   8504/9000  NMI Interrupt Handler
------------------ show interfaces ------------------
------------------ show controllers ------------------
Interface GigabitEthernet0 (idb 0x4674C998)
Hardware is BCM1250 Internal MAC (Revision B2/B3)
  network link is down  (SHUTDOWN)
  Config is Auto Speed, Auto Duplex
  Selected media-type is RJ45
  GBIC is not present
MAC Registers:
  mac_cfg =          0x000000C2000A0176, mac_thrsh_cfg = 0x0000080400084004
  mac_vlantag =      0x0000000000000000, mac_frame_cfg = 0x05F4400000284500
  mac_adfilter_cfg = 0x0000000000000E28, mac_enable    = 0x0000000000000000
  mac_status =       0x0000000000000000, mac_int_mask  = 0x00004F0000C300C3
  mac_txd_ctl =      0x000000000000000F, mac_eth_addr  = 0x0000000000000000
  mac_fifo_ptrs =    0x05F4400000284500, mac_eopcnt    = 0x0000440000000000
  MAC RX is disabled  RX DMA - channel 0 is disabled, channel 1 is disabled
  MAC TX is disabled  TX DMA - channel 0 is disabled, channel 1 is disabled
  Device status = Detection of speed/duplex by PHY incomplete - check link
PHY Registers:
  PHY is Marvell 88E1011S (Rev 1.3)
  Control                = 0x1800           Status                 = 0x7949
  PHY ID 1               = 0x0141           PHY ID 2               = 0x0C62
  Auto Neg Advertisement = 0x0DE1           Link Partner Ability   = 0x0000
  Auto Neg Expansion     = 0x0004           Next Page Tx           = 0x2801
  Link Partner Next Page = 0x0000           1000BaseT Control      = 0x0300
  1000BaseT Status       = 0x0000           Extended Status        = 0x3000
  PHY Specific Control   = 0x0008           PHY Specific Status    = 0x8100
  Interrupt Enable       = 0x6C00           Interrupt Status       = 0x0000
  Ext PHY Spec Control   = 0x0C64           Receive Error Counter  = 0x0000
  LED Control            = 0x4100
  Ext PHY Spec Control 2 = 0x000A           Ext PHY Spec Status    = 0x801F
  PHY says Link is DOWN
PHY is POWERED DOWN
  Physical Interface - RJ45
  AUTONEG - Our ability is     1000M/FD 1000M/HD 100M/FD 100M/HD 10M/FD 10M/HD Pause Capable (Asymmetric)
  AUTONEG - Partner ability is unavailable (link DOWN)
Internal Driver Information:
  lc_ip_turbo_fs = 0x40550BAC, ip_routecache = 0x11 (dfs = 0/mdfs = 0)
  rx cache size = 1000, rx cache end = 872
  max_mtu = 1524
  ring sizes: RX = 128, TX = 256
  rx_particle_size: 512
Rx Channel 0:
  dma_config0 =     0x0000000000800188, dma_config1 =    0x0208000000600021
  dma_dscr_base =   0x000000000D617640, dma_dscr_cnt =   0x0000000000000080
  dma_cur_dscr_a =  0x0000000000000000, dma_cur_dscr_b = 0x0000000000000000
  dma_cur_daddr  =  0x0000800000000000
  rxring = 0xED617640, shadow = 0x4674E460, head = 0 (0xED617640)
  rx_overrun=0, rx_nobuffer=0, rx_discard=0
  Error Interrupts: rx_int_dscr = 0, rx_int_derr = 0, rx_int_drop = 0
Tx Channel 0:
  dma_config0 =     0x0000000001000488, dma_config1 =    0x5161000000000010
  dma_dscr_base =   0x000000000D617E80, dma_dscr_cnt =   0x0000000000000000
  dma_cur_dscr_a =  0xEFF3C7FEE85FFCFF, dma_cur_dscr_b = 0xFEFF6DDF7FEFFF2F
  dma_cur_daddr  =  0x0000000000000000
  txring = 0xED617E80, shadow = 0x4674E698, head = 0, tail = 0, tx_count = 0
  Error Interrupts: tx_int_dscr = 0, tx_int_derr = 0, tx_int_dzero = 0
  chip_state = 3, ds->tx_limited = 0
  throttled = 0, enabled = 0, disabled = 0
  reset=3(init=1, restart=2), auto_restart=0
  tx_underflow = 0, tx_overflow = 0
  rx_underflow = 0, rx_overflow = 0
  descriptor mismatch = 0, fixed alignment = 0
  bad length = 0 dropped, 0 corrected
  unexpected sop = 0
Address Filter:
  Promiscuous mode OFF
  Exact match table (for unicast, maximum 8 entries):
    Entry 0 MAC Addr = 0017.e000.7b00
    (All other entries are empty)
  Hash match table (for multicast, maximum 8 entries):
    Entry 0 MAC Addr = 0100.0ccc.cccc
Statistics:
  Rx Bytes                           0   Tx Bytes                           0
  Rx Good Packets                    0   Tx Good Packets                    0
  Rx Multicast                       0
  Rx Broadcast                       0
  Rx Bad Pkt Errors                  0   Tx Bad Pkt Errors                  0
  Rx FCS Errors                      0   Tx FCS Errors                      0
  Rx Runt Errors                     0   Tx Runt Errors                     0
  Rx Oversize Errors                 0   Tx Oversize Errors                 0
  Rx Length Errors                   0   Tx Collisions                      0
  Rx Code Errors                     0   Tx Late Collisions                 0
  Rx Dribble Errors                  0   Tx Excessive Collisions            0
                                         Tx Abort Errors                    0
Interface GigabitEthernet1 (idb 0x46761DF0)
  GBIC is not present
MAC Registers:
PHY Registers:
PHY is POWERED DOWN
  max_mtu = 1524
Rx Channel 0:
  dma_dscr_base =   0x000000000D6B5300, dma_dscr_cnt =   0x0000000000000080
  rxring = 0xED6B5300, shadow = 0x467638B8, head = 0 (0xED6B5300)
Tx Channel 0:
  dma_dscr_base =   0x000000000D6B5B40, dma_dscr_cnt =   0x0000000000000000
  dma_cur_dscr_a =  0x57DFEFCFFDF73FDB, dma_cur_dscr_b = 0xFDF73EFFD3BFC9EA
  txring = 0xED6B5B40, shadow = 0x46763AF0, head = 0, tail = 0, tx_count = 0
  reset=1(init=1, restart=0), auto_restart=0
  unexpected sop = 0
Address Filter:
    Entry 0 MAC Addr = 0017.e000.7b01
Statistics:
  Rx Multicast                       0
  Rx Broadcast                       0
                                         Tx Abort Errors                    0
Interface GigabitEthernet2 (idb 0x46776FD8)
  Network connection mode is FORCE
  network link is up
  Config is Auto Speed, Full Duplex
  Selected media-type is GBIC
  GBIC type is 1000BaseSX
MAC Registers:
  mac_cfg =          0x000000C8000A0176, mac_thrsh_cfg = 0x0000080400084004
  mac_vlantag =      0x0000000000000000, mac_frame_cfg = 0x05F4400000280200
  mac_adfilter_cfg = 0x0000000000000E28, mac_enable    = 0x0000000000000C11
  mac_status =       0x0000000000040000, mac_int_mask  = 0x00004F0000C300C3
  mac_fifo_ptrs =    0x05F4400000280200, mac_eopcnt    = 0x000044001F1F1F1F
  MAC RX is enabled  RX DMA - channel 0 is enabled, channel 1 is disabled
  MAC TX is enabled  TX DMA - channel 0 is enabled, channel 1 is disabled
  Device status = 1000 Mbps, Full-Duplex
PHY Registers:
  Control                = 0x0140           Status                 = 0x794D
  Auto Neg Advertisement = 0x0000           Link Partner Ability   = 0x0000
  Auto Neg Expansion     = 0x0000           Next Page Tx           = 0x2001
  Link Partner Next Page = 0x0000           1000BaseT Control      = 0x0000
  1000BaseT Status       = 0x0000           Extended Status        = 0xC000
  PHY Specific Control   = 0x0008           PHY Specific Status    = 0xAD00
  Interrupt Enable       = 0x6800           Interrupt Status       = 0x0000
  Ext PHY Spec Control 2 = 0x000A           Ext PHY Spec Status    = 0xA017
  PHY says Link is UP, Speed 1000Mbps, Full-Duplex [FIXED Speed/Duplex]
  Physical Interface - GBIC
GBIC registers:
  Register 0x00:   03  04  07  00  00  00  01  00
  Register 0x08:   00  00  00  01  0D  00  00  00
  Register 0x10:   37  1B  00  00  43  49  53  43
  Register 0x18:   4F  2D  46  49  4E  49  53  41
  Register 0x20:   52  20  20  20  00  00  90  65
  Register 0x28:   46  54  4C  46  38  35  31  39
  Register 0x30:   50  32  42  43  4C  2D  43  53
  Register 0x38:   30  30  30  30  03  52  00  9C
  Register 0x40:   00  12  00  00  46  4E  53  31
  Register 0x48:   31  31  38  30  37  34  4C  20
  Register 0x50:   20  20  20  20  30  37  30  34
  Register 0x58:   32  39  20  20  08  00  00  C9
  Register 0x60:   00  00  02  62  EC  8D  3C  7D
  Register 0x68:   AE  91  D2  A8  D7  A3  68  78
  Register 0x70:   77  48  DB  00  00  00  00  00
  Register 0x78:   00  00  00  00  3B  B3  20  F5
  PartNumber: FTLF8519P2BCL-CS
  PartRev: T
  SerialNo: FNS1118074L
  Options:  0
  Length(9um/50um/62.5um): 000/550/270
  Date Code: 070429
  Gigabit Ethernet Codes:  1
  max_mtu = 1524
Rx Channel 0:
  dma_dscr_base =   0x000000000D752FC0, dma_dscr_cnt =   0x0000000000000080
  dma_cur_dscr_a =  0x000010000D768382, dma_cur_dscr_b = 0x0100000000000001
  dma_cur_daddr  =  0x000080000D7534C0
  rxring = 0xED752FC0, shadow = 0x46778AA0, head = 95 (0xED7535B0)
Tx Channel 0:
  dma_dscr_base =   0x000000000D753800, dma_dscr_cnt =   0x0000000000000000
  dma_cur_dscr_a =  0x800013000C06A40A, dma_cur_dscr_b = 0x0938000000000003
  dma_cur_daddr  =  0x000000000D753EF0
  txring = 0xED753800, shadow = 0x46778CD8, head = 24, tail = 25, tx_count = 1
  chip_state = 2, ds->tx_limited = 0
  reset=5(init=1, restart=4), auto_restart=3
  unexpected sop = 0
Address Filter:
    Entry 0 MAC Addr = 0017.e000.7b02
    Entry 1 MAC Addr = 0100.5e00.0005
Statistics:
  Rx Bytes                209887367758   Tx Bytes               4491569131964
  Rx Good Packets           2206743188   Tx Good Packets           3946803488
  Rx Multicast                  425976
  Rx Broadcast                       2
                                         Tx Abort Errors                    0
Serial2/0.1/1/1/1:0
Slot 2 is a PA CC with the following PA in its slot0:
Serial2/0.1/1/1/2:0
Serial2/0.1/1/1/3:0
Serial2/0.1/1/2/1:0
Serial2/0.1/1/2/2:0
Serial2/0.1/1/2/3:0
Serial2/0.1/1/3/1:0
Serial2/0.1/1/3/2:0
Serial2/0.1/1/3/3:0
Serial2/0.1/1/4/1:0
Serial2/0.1/1/4/2:0
Serial2/0.1/1/4/3:0
Serial2/0.1/1/5/1:0
Serial2/0.1/1/5/2:0
Serial2/0.1/1/5/3:0
Serial2/0.1/1/6/1:0
Serial2/0.1/1/6/2:0
Serial2/0.1/1/6/3:0
Serial2/0.1/1/7/1:0
Serial2/0.1/1/7/2:0
Serial2/0.1/1/7/3:0
Serial2/0.1/2/1/1:0
Serial2/0.1/2/1/2:0
Serial2/0.1/2/1/3:0
Serial2/0.1/2/2/1:0
Serial2/0.1/2/2/2:0
Serial2/0.1/2/2/3:0
Serial2/0.1/2/3/1:0
Serial2/0.1/2/3/2:0
Serial2/0.1/2/3/3:0
Serial2/0.1/2/4/1:0
Serial2/0.1/2/4/2:0
Serial2/0.1/2/4/3:0
Serial2/0.1/2/5/1:0
Serial2/0.1/2/5/2:0
Serial2/0.1/2/5/3:0
Serial2/0.1/2/6/1:0
Serial2/0.1/2/6/2:0
Serial2/0.1/2/6/3:0
Serial2/0.1/2/7/1:0
Serial2/0.1/2/7/2:0
Serial2/0.1/2/7/3:0
Serial2/0.1/3/1/1:0
Serial2/0.1/3/1/2:0
Serial2/0.1/3/1/3:0
Serial2/0.1/3/2/1:0
Serial2/0.1/3/2/2:0
Serial2/0.1/3/2/3:0
Serial2/0.1/3/3/1:0
Serial2/0.1/3/3/2:0
Serial2/0.1/3/3/3:0
Serial2/0.1/3/4/1:0
Serial2/0.1/3/4/2:0
Serial2/0.1/3/4/3:0
Serial2/0.1/3/5/1:0
Serial2/0.1/3/5/2:0
Serial2/0.1/3/5/3:0
Serial2/0.1/3/6/1:0
Serial2/0.1/3/6/2:0
Serial2/0.1/3/6/3:0
Serial2/0.1/3/7/1:0
Serial2/0.1/3/7/2:0
Serial3/0.1/1/1/1:0
Slot 3 is a PA CC with the following PA in its slot0:
Serial3/0.1/1/1/2:0
Serial3/0.1/1/1/3:0
Serial3/0.1/1/2/1:0
Serial3/0.1/1/2/2:0
Serial3/0.1/1/2/3:0
Serial3/0.1/1/3/1:0
Serial3/0.1/1/3/2:0
Serial3/0.1/1/3/3:0
Serial3/0.1/1/4/1:0
Serial3/0.1/1/4/2:0
Serial3/0.1/1/4/3:0
Serial3/0.1/1/5/1:0
Serial3/0.1/1/5/2:0
Serial3/0.1/1/5/3:0
Serial3/0.1/1/6/1:0
Serial3/0.1/1/6/2:0
Serial3/0.1/1/6/3:0
Serial3/0.1/1/7/1:0
Serial3/0.1/1/7/2:0
Serial3/0.1/1/7/3:0
Serial3/0.1/2/1/1:0
Serial3/0.1/2/1/2:0
Serial3/0.1/2/1/3:0
Serial3/0.1/2/2/1:0
Serial3/0.1/2/2/2:0
Serial3/0.1/2/2/3:0
Serial3/0.1/2/3/1:0
Serial3/0.1/2/3/2:0
Serial3/0.1/2/3/3:0
Serial3/0.1/2/4/1:0
Serial3/0.1/2/4/2:0
Serial3/0.1/2/4/3:0
Serial3/0.1/2/5/1:0
Serial3/0.1/2/5/2:0
Serial3/0.1/2/5/3:0
Serial3/0.1/2/6/1:0
Serial3/0.1/2/6/2:0
Serial3/0.1/2/6/3:0
Serial3/0.1/2/7/1:0
Serial3/0.1/2/7/2:0
Serial3/0.1/2/7/3:0
Serial3/0.1/3/1/1:0
Serial3/0.1/3/1/2:0
Serial3/0.1/3/1/3:0
Serial3/0.1/3/2/1:0
Serial3/0.1/3/2/2:0
Serial3/0.1/3/2/3:0
Serial3/0.1/3/3/1:0
Serial3/0.1/3/3/2:0
Serial3/0.1/3/3/3:0
Serial3/0.1/3/4/1:0
Serial3/0.1/3/4/2:0
Serial3/0.1/3/4/3:0
Serial3/0.1/3/5/1:0
Serial3/0.1/3/5/2:0
Serial3/0.1/3/5/3:0
Serial3/0.1/3/6/1:0
Serial3/0.1/3/6/2:0
Serial3/0.1/3/6/3:0
Serial4/0.1/1/1/1:0
Slot 4 is a PA CC with the following PA in its slot0:
Serial4/0.1/1/1/2:0
Serial4/0.1/1/1/3:0
Serial4/0.1/1/2/1:0
Serial4/0.1/1/2/2:0
Serial4/0.1/1/2/3:0
Serial4/0.1/1/3/1:0
Serial4/0.1/1/3/2:0
Serial4/0.1/1/4/1:0
Serial4/0.1/1/4/2:0
Serial4/0.1/1/5/1:0
Serial4/0.1/1/5/2:0
Serial4/0.1/1/5/3:0
Serial4/0.1/1/6/1:0
Serial4/0.1/1/6/2:0
Serial4/0.1/1/7/1:0
Serial4/0.1/1/7/2:0
Serial4/0.1/2/1/1:0
Serial4/0.1/2/1/2:0
Serial4/0.1/2/1/3:0
Serial4/0.1/2/2/1:0
Serial4/0.1/2/2/2:0
Serial4/0.1/2/2/3:0
Serial4/0.1/2/3/1:0
Serial4/0.1/2/4/1:0
Serial4/0.1/2/4/2:0
Serial4/0.1/2/4/3:0
Serial4/0.1/2/5/1:0
Serial4/0.1/2/5/2:0
Serial4/0.1/2/6/1:0
Serial4/0.1/2/6/2:0
Serial4/0.1/2/7/1:0
Serial4/0.1/2/7/2:0
Serial4/0.1/3/1/1:0
Serial4/0.1/3/1/2:0
Serial4/0.1/3/1/3:0
Serial4/0.1/3/2/1:0
Serial4/0.1/3/2/2:0
Serial4/0.1/3/3/1:0
Serial4/0.1/3/4/1:0
Serial4/0.1/3/4/2:0
Serial4/0.1/3/5/1:0
Serial4/0.1/3/5/2:0
Serial4/0.1/3/6/1:0
Serial4/0.1/3/6/2:0
Serial4/0.1/3/7/1:0
Serial4/0.1/3/7/2:0
Serial5/0.1/1/1/1:0
Slot 5 is a PA CC with the following PA in its slot0:
Serial5/0.1/1/1/2:0
Serial5/0.1/1/1/3:0
Serial5/0.1/1/2/1:0
Serial5/0.1/1/2/2:0
Serial5/0.1/1/2/3:0
Serial5/0.1/1/3/1:0
Serial5/0.1/1/3/2:0
Serial5/0.1/1/3/3:0
Serial5/0.1/1/4/1:0
Serial5/0.1/1/4/2:0
Serial5/0.1/1/4/3:0
Serial5/0.1/1/5/1:0
Serial5/0.1/1/5/2:0
Serial5/0.1/1/5/3:0
Serial5/0.1/1/6/1:0
Serial5/0.1/1/6/2:0
Serial5/0.1/1/6/3:0
Serial5/0.1/1/7/1:0
Serial5/0.1/1/7/2:0
Serial5/0.1/1/7/3:0
Serial5/0.1/2/1/1:0
Serial5/0.1/2/1/2:0
Serial5/0.1/2/1/3:0
Serial5/0.1/2/2/1:0
Serial5/0.1/2/2/2:0
Serial5/0.1/2/2/3:0
Serial5/0.1/2/3/1:0
Serial5/0.1/2/3/2:0
Serial5/0.1/2/3/3:0
Serial5/0.1/2/4/1:0
Serial5/0.1/2/4/2:0
Serial5/0.1/2/4/3:0
Serial5/0.1/2/5/1:0
Serial5/0.1/2/5/3:0
Serial5/0.1/2/6/1:0
Serial5/0.1/2/6/2:0
Serial5/0.1/2/6/3:0
Serial5/0.1/2/7/1:0
Serial5/0.1/3/1/1:0
Serial5/0.1/3/1/2:0
Serial5/0.1/3/1/3:0
Serial5/0.1/3/2/1:0
Serial5/0.1/3/2/2:0
Serial5/0.1/3/2/3:0
Serial5/0.1/3/3/1:0
Serial5/0.1/3/3/2:0
Serial5/0.1/3/3/3:0
Serial5/0.1/3/4/1:0
Serial5/0.1/3/4/2:0
Serial5/0.1/3/4/3:0
Serial5/0.1/3/5/1:0
Serial5/0.1/3/5/2:0
Serial5/0.1/3/5/3:0
Serial5/0.1/3/6/1:0
Serial5/0.1/3/6/2:0
Serial5/0.1/3/6/3:0
Serial5/0.1/3/7/1:0
Serial5/0.1/3/7/2:0
SONET 2/0 is up.
Channelized OC-3/STM-1 SMI PA
  H/W Version : 24.257.2.5, ROM Version : 1.2
  FREEDM version : 2, F/W Version : 1.19.0
  Applique type is Channelized Sonet/SDH
  Description: dianxinju-155M-ADM16/1-TS2-1:6.6.6.*:timeslot*4-3
  Clock Source is Line, AUG mapping is AU4.
Medium info:
  Type: SDH, Line Coding: NRZ, Line Type: Short SM
Regenerator Section Status:
  No alarms detected.
Multiplex Section Status:
  No alarms detected.
  No BER failure/degrade detected
  BER_SF threshold power : 3
  BER_SD threshold power : 6
Higher Order Path Status:
  Path# 1 has no defects
Lower Order Path Status:
  VC-12 1/1/1/1 has no defects
  VC-12 1/1/1/2 has no defects
  VC-12 1/1/1/3 has no defects
  VC-12 1/1/2/1 has no defects
  VC-12 1/1/2/2 has no defects
  VC-12 1/1/2/3 has no defects
  VC-12 1/1/3/1 has no defects
  VC-12 1/1/3/2 has no defects
  VC-12 1/1/3/3 has no defects
  VC-12 1/1/4/1 has no defects
  VC-12 1/1/4/2 has no defects
  VC-12 1/1/4/3 has no defects
  VC-12 1/1/5/1 has no defects
  VC-12 1/1/5/2 has no defects
  VC-12 1/1/5/3 has no defects
  VC-12 1/1/6/1 has no defects
  VC-12 1/1/6/2 has no defects
  VC-12 1/1/6/3 has no defects
  VC-12 1/1/7/1 has no defects
  VC-12 1/1/7/2 has no defects
  VC-12 1/1/7/3 has no defects
  VC-12 1/2/1/1 has no defects
  VC-12 1/2/1/2 has no defects
  VC-12 1/2/1/3 has no defects
  VC-12 1/2/2/1 has no defects
  VC-12 1/2/2/2 has no defects
  VC-12 1/2/2/3 has no defects
  VC-12 1/2/3/1 has defects
    LP-UNEQ     LP-PLM
  VC-12 1/2/3/2 has defects
    LP-UNEQ     LP-PLM
  VC-12 1/2/3/3 has no defects
  VC-12 1/2/4/1 has no defects
  VC-12 1/2/4/2 has no defects
  VC-12 1/2/4/3 has no defects
  VC-12 1/2/5/1 has no defects
  VC-12 1/2/5/2 has no defects
  VC-12 1/2/5/3 has no defects
  VC-12 1/2/6/1 has no defects
  VC-12 1/2/6/2 has no defects
  VC-12 1/2/6/3 has no defects
  VC-12 1/2/7/1 has no defects
  VC-12 1/2/7/2 has no defects
  VC-12 1/2/7/3 has no defects
  VC-12 1/3/1/1 has no defects
  VC-12 1/3/1/2 has no defects
  VC-12 1/3/1/3 has no defects
  VC-12 1/3/2/1 has no defects
  VC-12 1/3/2/2 has no defects
  VC-12 1/3/2/3 has no defects
  VC-12 1/3/3/1 has no defects
  VC-12 1/3/3/2 has no defects
  VC-12 1/3/3/3 has no defects
  VC-12 1/3/4/1 has no defects
  VC-12 1/3/4/2 has no defects
  VC-12 1/3/4/3 has no defects
  VC-12 1/3/5/1 has no defects
  VC-12 1/3/5/2 has no defects
  VC-12 1/3/5/3 has no defects
  VC-12 1/3/6/1 has no defects
  VC-12 1/3/6/2 has no defects
  VC-12 1/3/6/3 has no defects
  VC-12 1/3/7/1 has no defects
  VC-12 1/3/7/2 has no defects
  VC-12 1/3/7/3 has no defects
  Data in current interval (712 seconds elapsed):
   Regenerator Section:
     0 CVs, 0 ESs, 0 SESs, 0 SEFSs
   Multiplex Section:
     0 CVs, 0 ESs, 0 SESs, 0 UASs
   Higher Order Path:
     Path# 1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
   Lower Order Path:
     VC-12 1/1/1/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/1/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/1/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/2/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/2/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/2/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/3/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/3/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/3/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/4/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/4/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/4/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/5/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/5/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/5/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/6/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/6/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/6/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/7/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/7/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/1/7/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/1/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/1/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/1/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/2/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/2/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/2/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/3/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/3/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/3/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/4/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/4/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/4/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/5/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/5/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/5/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/6/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/6/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/6/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/7/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/7/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/2/7/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/1/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/1/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/1/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/2/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/2/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/2/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/3/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/3/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/3/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/4/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/4/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/4/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/5/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/5/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/5/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/6/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/6/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/6/3:  41 CVs, 1 ESs, 1 SESs, 0 UASs
     VC-12 1/3/7/1:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/7/2:  0 CVs, 0 ESs, 0 SESs, 0 UASs
     VC-12 1/3/7/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
SONET 2/0   E1   1/1/1/1 is up
  Framing is none, Clock Source is line.
SONET 2/0   E1   1/1/1/2 is up
SONET 2/0   E1   1/1/1/3 is up
SONET 2/0   E1   1/1/2/1 is up
SONET 2/0   E1   1/1/2/2 is up
SONET 2/0   E1   1/1/2/3 is up
SONET 2/0   E1   1/1/3/1 is up
SONET 2/0   E1   1/1/3/2 is up
SONET 2/0   E1   1/1/3/3 is up
SONET 2/0   E1   1/1/4/1 is up
SONET 2/0   E1   1/1/4/2 is up
SONET 2/0   E1   1/1/4/3 is up
SONET 2/0   E1   1/1/5/1 is up
SONET 2/0   E1   1/1/5/2 is up
SONET 2/0   E1   1/1/5/3 is up
SONET 2/0   E1   1/1/6/1 is up
SONET 2/0   E1   1/1/6/2 is up
SONET 2/0   E1   1/1/6/3 is up
SONET 2/0   E1   1/1/7/1 is up
SONET 2/0   E1   1/1/7/2 is up
SONET 2/0   E1   1/1/7/3 is up
SONET 2/0   E1   1/2/1/1 is up
SONET 2/0   E1   1/2/1/2 is up
SONET 2/0   E1   1/2/1/3 is up
SONET 2/0   E1   1/2/2/1 is up
SONET 2/0   E1   1/2/2/2 is up
SONET 2/0   E1   1/2/2/3 is up
SONET 2/0   E1   1/2/3/1 is down
SONET 2/0   E1   1/2/3/2 is down
SONET 2/0   E1   1/2/3/3 is up
SONET 2/0   E1   1/2/4/1 is up
SONET 2/0   E1   1/2/4/2 is up
SONET 2/0   E1   1/2/4/3 is up
SONET 2/0   E1   1/2/5/1 is up
SONET 2/0   E1   1/2/5/2 is up
SONET 2/0   E1   1/2/5/3 is up
SONET 2/0   E1   1/2/6/1 is up
SONET 2/0   E1   1/2/6/2 is up
SONET 2/0   E1   1/2/6/3 is up
SONET 2/0   E1   1/2/7/1 is up
SONET 2/0   E1   1/2/7/2 is up
SONET 2/0   E1   1/2/7/3 is up
SONET 2/0   E1   1/3/1/1 is up
SONET 2/0   E1   1/3/1/2 is up
SONET 2/0   E1   1/3/1/3 is up
SONET 2/0   E1   1/3/2/1 is up
SONET 2/0   E1   1/3/2/2 is up
SONET 2/0   E1   1/3/2/3 is up
SONET 2/0   E1   1/3/3/1 is up
SONET 2/0   E1   1/3/3/2 is up
SONET 2/0   E1   1/3/3/3 is up
SONET 2/0   E1   1/3/4/1 is up
SONET 2/0   E1   1/3/4/2 is up
SONET 2/0   E1   1/3/4/3 is up
SONET 2/0   E1   1/3/5/1 is up
SONET 2/0   E1   1/3/5/2 is up
SONET 2/0   E1   1/3/5/3 is up
SONET 2/0   E1   1/3/6/1 is up
SONET 2/0   E1   1/3/6/2 is up
SONET 2/0   E1   1/3/6/3 is up
SONET 2/0   E1   1/3/7/1 is up
SONET 2/0   E1   1/3/7/2 is up
SONET 2/0   E1   1/3/7/3 is down
  Not configured.
SONET 3/0 is up.
  Description: :dianxinju155M-lc319-ts3-1:6.6.11.*:timeslot*4-3
Medium info:
  No alarms detected.
  No alarms detected.
  VC-12 1/2/3/1 has no defects
  VC-12 1/2/3/2 has no defects
  VC-12 1/3/5/2 has defects
    LP-UNEQ     LP-PLM
  VC-12 1/3/5/3 has defects
    LP-UNEQ     LP-PLM
  VC-12 1/3/6/1 has defects
    LP-UNEQ     LP-PLM
  VC-12 1/3/6/2 has defects
    LP-UNEQ     LP-PLM
  VC-12 1/3/6/3 has defects
    LP-UNEQ     LP-PLM
  Data in current interval (733 seconds elapsed):
   Multiplex Section:
   Higher Order Path:
   Lower Order Path:
     VC-12 1/3/3/3:  52 CVs, 1 ESs, 1 SESs, 0 UASs
     VC-12 1/3/6/3:  0 CVs, 0 ESs, 0 SESs, 0 UASs
SONET 3/0   E1   1/1/1/1 is up
SONET 3/0   E1   1/1/1/2 is up
SONET 3/0   E1   1/1/1/3 is up
SONET 3/0   E1   1/1/2/1 is up
SONET 3/0   E1   1/1/2/2 is up
SONET 3/0   E1   1/1/2/3 is up
SONET 3/0   E1   1/1/3/1 is up
SONET 3/0   E1   1/1/3/2 is up
SONET 3/0   E1   1/1/3/3 is up
SONET 3/0   E1   1/1/4/1 is up
SONET 3/0   E1   1/1/4/2 is up
SONET 3/0   E1   1/1/4/3 is up
SONET 3/0   E1   1/1/5/1 is up
SONET 3/0   E1   1/1/5/2 is up
SONET 3/0   E1   1/1/5/3 is up
SONET 3/0   E1   1/1/6/1 is up
SONET 3/0   E1   1/1/6/2 is up
SONET 3/0   E1   1/1/6/3 is up
SONET 3/0   E1   1/1/7/1 is up
SONET 3/0   E1   1/1/7/2 is up
SONET 3/0   E1   1/1/7/3 is up
SONET 3/0   E1   1/2/1/1 is up
SONET 3/0   E1   1/2/1/2 is up
SONET 3/0   E1   1/2/1/3 is up
SONET 3/0   E1   1/2/2/1 is up
SONET 3/0   E1   1/2/2/2 is up
SONET 3/0   E1   1/2/2/3 is up
SONET 3/0   E1   1/2/3/1 is up
SONET 3/0   E1   1/2/3/2 is up
SONET 3/0   E1   1/2/3/3 is up
SONET 3/0   E1   1/2/4/1 is up
SONET 3/0   E1   1/2/4/2 is up
SONET 3/0   E1   1/2/4/3 is up
SONET 3/0   E1   1/2/5/1 is up
SONET 3/0   E1   1/2/5/2 is up
SONET 3/0   E1   1/2/5/3 is up
SONET 3/0   E1   1/2/6/1 is up
SONET 3/0   E1   1/2/6/2 is up
SONET 3/0   E1   1/2/6/3 is up
SONET 3/0   E1   1/2/7/1 is up
SONET 3/0   E1   1/2/7/2 is up
SONET 3/0   E1   1/2/7/3 is up
SONET 3/0   E1   1/3/1/1 is up
SONET 3/0   E1   1/3/1/2 is up
SONET 3/0   E1   1/3/1/3 is up
SONET 3/0   E1   1/3/2/1 is up
SONET 3/0   E1   1/3/2/2 is up
SONET 3/0   E1   1/3/2/3 is up
SONET 3/0   E1   1/3/3/1 is up
SONET 3/0   E1   1/3/3/2 is up
SONET 3/0   E1   1/3/3/3 is up
SONET 3/0   E1   1/3/4/1 is up
SONET 3/0   E1   1/3/4/2 is up
SONET 3/0   E1   1/3/4/3 is up
SONET 3/0   E1   1/3/5/1 is up
SONET 3/0   E1   1/3/5/2 is down
SONET 3/0   E1   1/3/5/3 is down
SONET 3/0   E1   1/3/6/1 is down
SONET 3/0   E1   1/3/6/2 is down
SONET 3/0   E1   1/3/6/3 is down
SONET 3/0   E1   1/3/7/1 is down
  Not configured.
SONET 3/0   E1   1/3/7/2 is down
  Not configured.
SONET 3/0   E1   1/3/7/3 is down
  Not configured.
SONET 4/0 is up.
  Description: :wangtong155M:6.6.8.*:timeslot*4-3 205-2-1
Medium info:
  No alarms detected.
  No alarms detected.
  VC-12 1/3/1/1 has defects
    TU-LOP
  Data in current interval (205 seconds elapsed):
   Multiplex Section:
   Higher Order Path:
   Lower Order Path:
     VC-12 1/3/7/3:  0 CVs, 0 ESs, 0 SESs, 205 UASs
SONET 4/0   E1   1/1/1/1 is up
SONET 4/0   E1   1/1/1/2 is up
SONET 4/0   E1   1/1/1/3 is up
SONET 4/0   E1   1/1/2/1 is up
SONET 4/0   E1   1/1/2/2 is up
SONET 4/0   E1   1/1/2/3 is up
SONET 4/0   E1   1/1/3/1 is up
SONET 4/0   E1   1/1/3/2 is up
SONET 4/0   E1   1/1/3/3 is down
  Not configured.
SONET 4/0   E1   1/1/4/1 is up
SONET 4/0   E1   1/1/4/2 is up
SONET 4/0   E1   1/1/4/3 is down
  Not configured.
SONET 4/0   E1   1/1/5/1 is up
SONET 4/0   E1   1/1/5/2 is up
SONET 4/0   E1   1/1/5/3 is up
SONET 4/0   E1   1/1/6/1 is up
SONET 4/0   E1   1/1/6/2 is up
SONET 4/0   E1   1/1/6/3 is down
  Not configured.
SONET 4/0   E1   1/1/7/1 is up
SONET 4/0   E1   1/1/7/2 is up
SONET 4/0   E1   1/1/7/3 is down
  Not configured.
SONET 4/0   E1   1/2/1/1 is up
SONET 4/0   E1   1/2/1/2 is up
SONET 4/0   E1   1/2/1/3 is up
SONET 4/0   E1   1/2/2/1 is up
SONET 4/0   E1   1/2/2/2 is up
SONET 4/0   E1   1/2/2/3 is up
SONET 4/0   E1   1/2/3/1 is up
SONET 4/0   E1   1/2/3/2 is down
  Not configured.
SONET 4/0   E1   1/2/3/3 is down
  Not configured.
SONET 4/0   E1   1/2/4/1 is up
SONET 4/0   E1   1/2/4/2 is up
SONET 4/0   E1   1/2/4/3 is up
SONET 4/0   E1   1/2/5/1 is up
SONET 4/0   E1   1/2/5/2 is up
SONET 4/0   E1   1/2/5/3 is down
  Not configured.
SONET 4/0   E1   1/2/6/1 is up
SONET 4/0   E1   1/2/6/2 is up
SONET 4/0   E1   1/2/6/3 is down
  Not configured.
SONET 4/0   E1   1/2/7/1 is up
SONET 4/0   E1   1/2/7/2 is up
SONET 4/0   E1   1/2/7/3 is down
  Not configured.
SONET 4/0   E1   1/3/1/1 is down
SONET 4/0   E1   1/3/1/2 is up
SONET 4/0   E1   1/3/1/3 is up
SONET 4/0   E1   1/3/2/1 is up
SONET 4/0   E1   1/3/2/2 is up
SONET 4/0   E1   1/3/2/3 is down
  Not configured.
SONET 4/0   E1   1/3/3/1 is up
SONET 4/0   E1   1/3/3/2 is down
  Not configured.
SONET 4/0   E1   1/3/3/3 is down
  Not configured.
SONET 4/0   E1   1/3/4/1 is up
SONET 4/0   E1   1/3/4/2 is up
SONET 4/0   E1   1/3/4/3 is down
  Not configured.
SONET 4/0   E1   1/3/5/1 is up
SONET 4/0   E1   1/3/5/2 is up
SONET 4/0   E1   1/3/5/3 is down
  Not configured.
SONET 4/0   E1   1/3/6/1 is up
SONET 4/0   E1   1/3/6/2 is up
SONET 4/0   E1   1/3/6/3 is down
  Not configured.
SONET 4/0   E1   1/3/7/1 is up
SONET 4/0   E1   1/3/7/2 is up
SONET 4/0   E1   1/3/7/3 is down
  Not configured.
SONET 5/0 is up.
  Description: :liantong155M:6.6.9.*:timeslot*4-3 949-1-1
Medium info:
  No alarms detected.
  No alarms detected.
  VC-12 1/1/6/2 has defects
    TU-AIS     LP-PLM
  Data in current interval (711 seconds elapsed):
   Multiplex Section:
   Higher Order Path:
   Lower Order Path:
     VC-12 1/2/5/2:  0 CVs, 0 ESs, 0 SESs, 711 UASs
     VC-12 1/2/7/2:  0 CVs, 0 ESs, 0 SESs, 711 UASs
     VC-12 1/2/7/3:  0 CVs, 0 ESs, 0 SESs, 711 UASs
     VC-12 1/3/7/3:  0 CVs, 0 ESs, 0 SESs, 711 UASs
SONET 5/0   E1   1/1/1/1 is up
SONET 5/0   E1   1/1/1/2 is up
SONET 5/0   E1   1/1/1/3 is up
SONET 5/0   E1   1/1/2/1 is up
SONET 5/0   E1   1/1/2/2 is up
SONET 5/0   E1   1/1/2/3 is up
SONET 5/0   E1   1/1/3/1 is up
SONET 5/0   E1   1/1/3/2 is up
SONET 5/0   E1   1/1/3/3 is up
SONET 5/0   E1   1/1/4/1 is up
SONET 5/0   E1   1/1/4/2 is up
SONET 5/0   E1   1/1/4/3 is up
SONET 5/0   E1   1/1/5/1 is up
SONET 5/0   E1   1/1/5/2 is up
SONET 5/0   E1   1/1/5/3 is up
SONET 5/0   E1   1/1/6/1 is up
SONET 5/0   E1   1/1/6/2 is down
SONET 5/0   E1   1/1/6/3 is up
SONET 5/0   E1   1/1/7/1 is up
SONET 5/0   E1   1/1/7/2 is up
SONET 5/0   E1   1/1/7/3 is up
SONET 5/0   E1   1/2/1/1 is up
SONET 5/0   E1   1/2/1/2 is up
SONET 5/0   E1   1/2/1/3 is up
SONET 5/0   E1   1/2/2/1 is up
SONET 5/0   E1   1/2/2/2 is up
SONET 5/0   E1   1/2/2/3 is up
SONET 5/0   E1   1/2/3/1 is up
SONET 5/0   E1   1/2/3/2 is up
SONET 5/0   E1   1/2/3/3 is up
SONET 5/0   E1   1/2/4/1 is up
SONET 5/0   E1   1/2/4/2 is up
SONET 5/0   E1   1/2/4/3 is up
SONET 5/0   E1   1/2/5/1 is up
SONET 5/0   E1   1/2/5/2 is down
  Not configured.
SONET 5/0   E1   1/2/5/3 is up
SONET 5/0   E1   1/2/6/1 is up
SONET 5/0   E1   1/2/6/2 is up
SONET 5/0   E1   1/2/6/3 is up
SONET 5/0   E1   1/2/7/1 is up
SONET 5/0   E1   1/2/7/2 is down
  Not configured.
SONET 5/0   E1   1/2/7/3 is down
  Not configured.
SONET 5/0   E1   1/3/1/1 is up
SONET 5/0   E1   1/3/1/2 is up
SONET 5/0   E1   1/3/1/3 is up
SONET 5/0   E1   1/3/2/1 is up
SONET 5/0   E1   1/3/2/2 is up
SONET 5/0   E1   1/3/2/3 is up
SONET 5/0   E1   1/3/3/1 is up
SONET 5/0   E1   1/3/3/2 is up
SONET 5/0   E1   1/3/3/3 is up
SONET 5/0   E1   1/3/4/1 is up
SONET 5/0   E1   1/3/4/2 is up
SONET 5/0   E1   1/3/4/3 is up
SONET 5/0   E1   1/3/5/1 is up
SONET 5/0   E1   1/3/5/2 is up
SONET 5/0   E1   1/3/5/3 is up
SONET 5/0   E1   1/3/6/1 is up
SONET 5/0   E1   1/3/6/2 is up
SONET 5/0   E1   1/3/6/3 is up
SONET 5/0   E1   1/3/7/1 is up
SONET 5/0   E1   1/3/7/2 is up
SONET 5/0   E1   1/3/7/3 is down
  Not configured.
------------------ show user ------------------
    Line       User       Host(s)              Idle       Location
*  2 vty 0                  idle                 00:00:25
------------------ show data-corruption ------------------
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
---------------------- show bootdisk: all ------------------
-#- --length-- -----date/time------ path
1     26640436 Mar 14 2000 04:02:10 +08:00 c7300-js-mz.122-25.S5.bin
2         2654 Mar 31 2001 03:58:14 +08:00 crashinfo_pacc_4_20010330-195813
3         2655 May 20 2001 04:15:58 +08:00 crashinfo_pacc_4_20010519-201558
4         2761 Jun 4 2010 13:28:06 +08:00 crashinfo_pacc_4_20100604-052807
5         2758 Jun 5 2010 21:25:58 +08:00 crashinfo_pacc_4_20100605-132558
6         2758 Jun 11 2010 19:53:20 +08:00 crashinfo_pacc_4_20100611-115319
7         2758 Jun 14 2010 09:38:16 +08:00 crashinfo_pacc_4_20100614-013816
-------------- show memory statistics ------------------
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
   Number of Heads:       8
   Number of Cylinders    980
   Sectors per Cylinder   32
   Sector Size            512
   Total Sectors          250880
ATA CARD FORMAT
   Number of FAT Sectors  245
   Sectors Per Cluster    4
   Number of Clusters     62530
   Number of Data Sectors 250746
   Base Root Sector       592
   Base FAT Sector        102
   Base Data Sector       624
ATA MONLIB INFO
   Image Monlib size = 51448
   Disk monlib size = 52224
   Name = NA
   Monlib end sector = NA
   Monlib Start sector = NA
   Monlib updated by = NA
   Monlib version = NA
%Error show bootdisk: (Directory entries are corrupted, please format the disk)
------------------ show disk0: all ------------------
1     29238024 Feb 9 2004 17:01:50 +08:00 c7300-is-mz.122-31.SB15.bin
2     28766472 Oct 2 2002 10:04:30 +08:00 c7300-p-mz.122-31.SB11.bin
3     27888804 Jun 3 2010 17:59:18 +08:00 c7300-is-mz.122-28.SB13.bin
170602496 bytes available (85901312 bytes used)
ATA CARD GEOMETRY
   Number of Heads:       16
   Sector Size            512
   Total Sectors          501760
ATA CARD FORMAT
   Sectors Per Cluster    8
   Number of Clusters     62623
   Number of Data Sectors 501619
   Base Root Sector       599
   Base FAT Sector        109
   Base Data Sector       631
ATA MONLIB INFO
   Disk monlib size = 55808
   Name = c7300-atafslib-m
   Monlib Start sector = 2
   Monlib End sector = 102
   Monlib updated by = C7300-JS-M12.2(25)S5
   Monlib version = 1
------------------ dir nvram: ------------------
------------------ show redundancy states ------------------
       my state = 13 -ACTIVE
     peer state = 1  -DISABLED
           Mode = Simplex
           Unit = Primary
        Unit ID = 0
Redundancy Mode (Operational) = SSO
Redundancy Mode (Configured)  = SSO
Redundancy State              = Non Redundant
     Maintenance Mode = Disabled
Manual swact disabled (system is simplex (no peer unit))
Communications = Down      Reason: Simplex mode
   client count = 24
client_notification_TMR = 30000 milliseconds
           RF debug mask = 0x0
------------------ show ipc nodes ------------------
There are 5 nodes in this IPC realm.
   ID       Type               Name                             Last  Last
        Sent  Heard
0.10000    Local      IPC Master                               0      0
0.1020000  WSRP       WS Slot 2                                813    22613
0.1050000  WSRP       WS Slot 5                                783    42098
0.1030000  WSRP       WS Slot 3                                793    38794
0.1040000  WSRP       WS Slot 4                                242    30340
------------------ show ipc ports ------------------
There are 30 ports defined.
Port ID        Type       Name                    (current/peak/total)
   10000.1     unicast    IPC Master:Zone
   10000.2     unicast    IPC Master:Echo
   10000.3     unicast    IPC Master:Control
   10000.4     unicast    IPC Master:Init
   10000.5     unicast    WS event
     port_index = 0  seat_id = 0x1020000  last sent = 0     last heard = 52696
     rcv pending/peak/total       = 0/259/115658200
     port_index = 1  seat_id = 0x1040000  last sent = 0     last heard = 43563
     rcv pending/peak/total       = 0/258/5024299
     port_index = 2  seat_id = 0x1030000  last sent = 0     last heard = 52571
     rcv pending/peak/total       = 0/260/115658075
     port_index = 3  seat_id = 0x1050000  last sent = 0     last heard = 52500
     rcv pending/peak/total       = 0/260/115658004
   10000.6     unicast    IPC-Apps:Active
   10000.7     unicast    RF : Active
   10000.8     unicast    ifindex_sync_active_port
   10000.9     unicast    CF : Active
   10000.A     unicast    Config Sync ISSU nego active
   10000.B     unicast    RED MODE: Active Port
   10000.C     unicast    Remote TTY Server Port
     port_index = 0  seat_id = 0x1020000  last sent = 0     last heard = 1
     rcv pending/peak/total       = 0/1/1
     port_index = 1  seat_id = 0x1030000  last sent = 0     last heard = 1
     port_index = 2  seat_id = 0x1040000  last sent = 0     last heard = 1
     port_index = 3  seat_id = 0x1050000  last sent = 0     last heard = 1
   10000.D     unicast    FIB Master: DFS.process_level.msgs
   10000.E     unicast    FIB Master: DFS.interrupt.msgs
1020000.3     unicast    WS Slot2:Control
1020000.5     unicast    WS Slot2:Cmd
1020000.6     unicast    Slot 2/0: Remote TTY Client Port
1020000.4     unicast    Slot2: Console RPC Port
1030000.3     unicast    WS Slot3:Control
1050000.3     unicast    WS Slot5:Control
1030000.5     unicast    WS Slot3:Cmd
1030000.6     unicast    Slot 3/0: Remote TTY Client Port
1050000.5     unicast    WS Slot5:Cmd
1030000.4     unicast    Slot3: Console RPC Port
1050000.6     unicast    Slot 5/0: Remote TTY Client Port
1050000.4     unicast    Slot5: Console RPC Port
1040000.3     unicast    WS Slot4:Control
1040000.5     unicast    WS Slot4:Cmd
1040000.6     unicast    Slot 4/0: Remote TTY Client Port
1040000.4     unicast    Slot4: Console RPC Port
RPC packets: current/peak/total
                                                            0/1/7522686
------------------ show ipc queue ------------------
There are 0 IPC messages waiting for acknowledgement in the transmit queue.
There are 0 IPC messages waiting for a response.
There are 0 IPC messages waiting for additional fragments.
There are 0 IPC messages currently on the IPC inboundQ.
There are 0 IPC messages currently on the zone inboundQ.
Messages currently in use                     :         14
Message cache size                            :       5000
Maximum message cache usage                   :       5000
0  times message cache crossed      15000 [max]
Emergency messages currently in use           :          0
There are 13 messages currently reserved for reply msg.
------------------ show ipc status ------------------
                            IPC System Status
Time last IPC stat cleared : never
This processor is the IPC master server.
Do not drop output of IPC frames for test purposes.
5000 IPC Message Headers Cached.
                                                    Rx Side     Tx Side
Total Frames                                        477671513   955323289
Total from Local Ports                              470137807    15070605
Total Protocol Control Frames                         7535270   470126355
Total Frames Dropped                                        3           0
                             Service Usage
Total via Unreliable Connection-Less Service                0           0
Total via Unreliable Sequenced Connection-Less Svc       9888           0
Total via Reliable Connection-Oriented Service      470126352     7535281
                      IPC Protocol Version 0
Total Acknowledgements                                7535270   470126355
Total Negative Acknowledgements                             0           0
                             Device Drivers
Total via Local Driver                                      0           0
Total via Platform Driver                           477671513   477661679
Total Frames Dropped by Platform Drivers                    0           0
Total Frames Sent when media is quiesced                                0
                     Reliable Tx Statistics
Re-Transmission                                                        43
Re-Tx Timeout                                                           3
          Rx Errors                              Tx Errors
Unsupp IPC Proto Version          0  Tx Session Error                  0
Corrupt Frame                     0  Tx Seat Error                     0
Duplicate Frame                   3  Destination Unreachable           0
Rel Out-of-Seq Frame              0  Unrel Out-of-Seq Frame            0
Dest Port does Not Exist          0  Tx Driver Failed                  0
Rx IPC Msg Alloc Failed           0  Rx IPC Frag Dropped               0
Rx IPC Transform Errors           0  Tx IPC Transform Errors           0
Unable to Deliver Msg             0  Tx Test Drop                      0
Ctrl Frm Alloc Failed             0
          Buffer Errors                          Misc Errors
IPC Msg Alloc                     0  IPC Open Port                     0
Emer IPC Msg Alloc                0  No HWQ                            0
IPC Frame PakType Alloc           0  Hardware Error                    0
IPC Frame MemD Alloc              0  Invalid Messages                  0
          Tx Driver Errors
No Transport                      0
MTU Failure                       0
Dest does not Exist               0
------------------ show hw-module all fpd ------------------
% No cards with FPD support can be found in the system.
------------------ show hw-module subslot all oir ------------------
------------------ show hw-module subslot all brief ------------------
------------------ show hw-module subslot all config ------------------
------------------ show hw-module subslot all counters ------------------
------------------ show hw-module subslot all errors ------------------
------------------ show hw-module subslot all registers ------------------
------------------ show hw-module subslot all status ------------------
------------------ show inventory ------------------
NAME: "Chassis", DESCR: "7300 Chassis"
PID: CISCO7304           , VID: N/A , SN: SMQ1021N393
NAME: "module 0", DESCR: "Network Processing Engine 100 CPU Card"
PID: 7304-NPE-G100       , VID: N/A , SN: CAT101505QS
NAME: "module 2", DESCR: "Port Adapter Carrier Card"
PID: 7300-CC-PA          , VID: N/A , SN: CAT10150131
NAME: "module 2/0", DESCR: "Channelized STM-1 (single mode intermediate reach)"
PID: PA-MC-STM-1SMI      , VID: N/A , SN: JAE10244JF7
NAME: "module 3", DESCR: "Port Adapter Carrier Card"
PID: 7300-CC-PA          , VID: V02 , SN: CAT1211D02J
NAME: "module 3/0", DESCR: "Channelized STM-1 (single mode intermediate reach)"
PID: PA-MC-STM-1SMI      , VID: N/A , SN: JAE1213CGL9
NAME: "module 4", DESCR: "Port Adapter Carrier Card"
PID: 7300-CC-PA          , VID: N/A , SN: CAT09280EZ4
NAME: "module 4/0", DESCR: "Channelized STM-1 (single mode intermediate reach)"
PID: PA-MC-STM-1SMI      , VID: N/A , SN: JAE0918BNDN
NAME: "module 5", DESCR: "Port Adapter Carrier Card"
PID: 7300-CC-PA          , VID: V02 , SN: CAT11035C96
NAME: "module 5/0", DESCR: "Channelized STM-1 (single mode intermediate reach)"
PID: PA-MC-STM-1SMI      , VID: N/A , SN: JAE1050H2R4
NAME: "Power supply and Fan Module 1", DESCR: "Power supply and Fan Module"
PID: 7300-PWR-AC         , VID: V03 , SN: DCA100710M1
NAME: "Power supply and Fan Module 2", DESCR: "Power supply and Fan Module"
PID: 7300-PWR-AC         , VID: V03 , SN: DCA100710LY
------------------ show buffers ------------------
Buffer elements:
     1498 in free list (500 max allowed)
     598621056 hits, 0 misses, 1000 created
Public buffer pools:
Small buffers, 104 bytes (total 1024, permanent 1024):
     1012 in free list (128 min, 2048 max allowed)
     235366406 hits, 0 misses, 0 trims, 0 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 512, permanent 512):
     481 in free list (64 min, 1024 max allowed)
     24831331 hits, 0 misses, 0 trims, 0 created
Big buffers, 1536 bytes (total 500, permanent 500, peak 969 @ 3w3d):
     500 in free list (64 min, 500 max allowed)
     196227133 hits, 186 misses, 469 trims, 469 created
VeryBig buffers, 4520 bytes (total 10, permanent 10):
     10 in free list (0 min, 100 max allowed)
     5940046 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 2, permanent 2):
     2 in free list (0 min, 10 max allowed)
     2003609 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 2, permanent 2, peak 12 @ 2w0d):
     2 in free list (0 min, 4 max allowed)
     38994 hits, 550 misses, 1100 trims, 1100 created
Interface buffer pools:
IPC buffers, 4096 bytes (total 3456, permanent 3456, peak 3582 @ 3w4d):
     3442 in free list (1152 min, 4608 max allowed)
     970393999 hits, 42 fallbacks, 126 trims, 126 created
Header pools:
Header buffers, 0 bytes (total 511, permanent 256, peak 511 @ 3w4d):
     255 in free list (256 min, 1024 max allowed)
     171 hits, 85 misses, 0 trims, 255 created
     256 max cache size, 256 in cache
     14241597 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 128 bytes (total 512, permanent 512):
     0 in free list (0 min, 512 max allowed)
     512 hits, 0 misses
     512 max cache size, 512 in cache
     0 hits in cache, 0 misses in cache
Normal buffers, 512 bytes (total 2048, permanent 2048):
     2048 in free list (1024 min, 4096 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
HTF6/0 buffers, 512 bytes (total 8192, permanent 8192):
     4096 in free list (0 min, 8192 max allowed)
     4096 hits, 0 misses
     4096 max cache size, 2048 in cache
     2021183824 hits in cache, 0 misses in cache
     16 buffer threshold, 0 threshold transitions
Private particle pools:
HQF buffers, 0 bytes (total 128, permanent 128):
     128 in free list (0 min, 128 max allowed)
GigabitEthernet0 buffers, 512 bytes (total 1000, permanent 1000):
     0 in free list (0 min, 1000 max allowed)
     1000 hits, 0 fallbacks
     1000 max cache size, 872 in cache
     128 hits in cache, 0 misses in cache
     14 buffer threshold, 0 threshold transitions
GigabitEthernet1 buffers, 512 bytes (total 1000, permanent 1000):
GigabitEthernet2 buffers, 512 bytes (total 1000, permanent 1000):
     2298217125 hits in cache, 0 misses in cache
