Cisco ASA5510 routing from inside to insde
Answered Question
I have a inside net with adress 10.10.10.1 and a router on the inside net with address 10.10.10.2, client use 10.10.10.1 as default gw. Do the ASA support routing on the inside interface, for example routing 10.10.20.0/24 against 10.10.10.2? I found a FAQ for pix where it was not supported and wondering if it's the same for the ASA.
Johan
Overall Rating: 5 (1 ratings)
