6500 switch IDSM license
Jun 29th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Dear All ,
I have one Cisco 6509 switch and there is no support contract for this switch and I want to enable firewall service and IDSM-2 on this
Im planning to purchase Firewall services module 3.2 and 600M IDSM-2 Module
Now regarding the license .
What else I need to purchase to keep my IDS signature updated ? whether i need to purchase smartnet contract ?  Is there is any special license needed for FSM module or base license is enough ? Whether I need to buy any special license for 6500 for enabling FSM and IDSM module in 6500 ?
I appreciate your help regarding this questions . Useful comments will be rated
Haris P
Jon Marshall Tue, 06/29/2010 - 06:11
chatwithharis wrote:
Dear All ,
Haris P
Haris
1) You do not need any additional license for the 6500 to run the FWSM/IDSM modules
2) You do need a license for the ISDM or else you cannot add signatures when they are released by Cisco
3) The FWSM comes with 3 contexts, one admin and 2 other contexts which you are free to use as you wish. If you don't want/need any more than this then you do need an additional license for more contexts. So in this case the base license would be enough. If you need more than 2 contexts which are simply virtual firewalls you will need to purchase an additional license.
Jon
