MeetingPlace Express emailing password
Jun 29th, 2010
We are currently using version 2.1.1.2 MeetingPlace Express and have noticed that when the meeting notification email is sent out it doesn't give the meeting password, instead it just says Required.
The email template has :
<td colspan="1"><b>$notify_passwd</b></td>
    <td colspan="3">$notify_password</td>
These are defined in the language file as:
notify_passwd=Password:
notify_password=$cisco_Password
Also in the language file is:
## MISC
no_password=Not required
yes_password=Required
This is the actual text that is being sent instead of the password.
Is there a way to have the email display the meeting password?
vinayjaiswal Sun, 09/11/2011 - 22:41
I too am facing the same issue, did u get any solution for this?
Vinay
Natasa Ciric-Bu... Mon, 09/12/2011 - 00:03
  • Cisco Employee,
In the User Profile/Group, the parameter "Include password" should be set to Yes. Could you please check this.
Natasa
vinayjaiswal Mon, 09/12/2011 - 05:43
Thanks a lot,Natasa,
It  worked, but I am unable to rate this port
Vinay
