06-29-2010 05:01 AM - edited 03-03-2019 05:59 AM
For some reason I am stuck in rommon on a 7206 device, router cannot boot boot image and router dosnt contain any valid IOS either.
When I reset the router bootstrap process starts and goes through all file systems looking for a valid img. It ends up in rommon after not finding anything
boot: cannot find an executable image for this platform on device "slot0:" --> "slot1:" --> "bootflash:"
System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Socket jumper: not present Failsafe jumper: present = normal
FPGA revision 0x00000026
C7200 platform with 1046528 Kbytes of main memory'
When I have a look in the filesystem I find these files I try to manually boot it, dosnt work.
rommon 8 > dir bootflash:
File size Checksum File name
8621732 bytes (0x838ea4) 0xb56251b6 c7200p-boot-mz.124-15.T10.bin (deleted)
3429 bytes (0xd65) 0xb74ff744 c7200p-boot-mz.124-15.T10.bin
rommon 9 >
DELETED??? oh my
rommon 3 > dir slot2:
Directory of slot2:
2 5498 -rw- c7200p-boot-mz.124-15.T10.bin
rommon 4 > dir disk2:
Directory of disk2:
rommon 6 > boot slot2:c7200p-boot-mz.124-15.T10.bin
loadprog: bad file magic number: 0x0
boot: cannot load "disk2:c7200p-boot-mz.124-15.T10.bin"
rommon 7 >
rommon 7 > set
PS1=rommon ! >
WARM_REBOOT=FALSE
BSI=0
RANDOM_NUM=2064610670
CONFIG_FILE=bootflash:c7200p-boot-mz.124-15.T10.bin
RET_2_RTS=19:53:46 UTC Wed Jun 23 2010
RET_2_RCALTS=1277322827
?=1
rommon 8 >
I also tried to set confreg 0x2101 wont help.
So the question now is how should I get a new IOS + a new BOOT image for my router?
Obviously the orignal location of the boot img has been deleted, can it be undeleted?
regards
Chris
07-07-2010 01:40 PM
Hey Chris,
It certainly appears that the images on your flash card are corrupted. Are these the only 2 file systems that you have images on? The other option you would have is to remove the flash card, load a valid image on it from another chassis or your PC, and re-install it and try to boot from it. The router will likely complain that the card needs to be formatted in it before using, however. Outside of trying to boot from a remote image using TFTP, which may or may not work, you would likely need to replace the card.
Hope this helps.
Brandon
07-29-2010 08:13 AM
We had the same problem.
Our Solution -
On the Compact Flash we loaded a new boot image. We rebootedthe router with the Compact Flash inserted. The router automatically found the boot image on the Flash Card, and loaded up (this did take awhile for the router to find). Once it is loaded up you can get your IOS loaded up in ROMMON or it will boot normally. When you are back into the CLI be sure to copy the boot image from the Flash Card to BootFlash and you should be good to go.
Duane
