LMS 3.1 - Aniserver Failed to run
Jun 29th, 2010
I get this error                       ANIServer Failed to  run                     0                     -2                         1073741822                      N/A. I have change aniserver.properties file to this other(view attach).
How can I fix it?
Overall Rating: 3 (1 ratings)
Joel Monge Tue, 06/29/2010 - 08:28
  • Cisco Employee,
You need to add the server name on your ANIServer.properties under :
AniName=ANIServer6.0
For example:
AniName=ANIServer6.0-ServerName
j-fragoso Wed, 06/30/2010 - 03:08
I have added ServerName but it didn't work
any idea?
thanks
Joel Monge Wed, 06/30/2010 - 06:39
  • Cisco Employee,
Please post:
1. "pdshow" output.
2. ANIServer.properties.orig along with your current ANIServer.properties.
3. Latest ani.log.
Joel Monge Wed, 06/30/2010 - 06:55
  • Cisco Employee,
Please post your CSCOpx\campus\etc\cwsi\DeviceDiscovery.properties also.
Joel Monge Wed, 06/30/2010 - 07:29
  • Cisco Employee,
The ANIServer.properties you sent me is now missing the root path:
DEVICESROOT=.
Your other files seem good, so try adding the path here correctly again and see if that does the trick.
mserranocisco Thu, 07/01/2010 - 04:39
Hi Joel,
the same error after modify DEVICESROOT:
Cannot connect to ANI server:
Verify that ANIServer6.0-XTD-990-SRV-01 is running and restart Campus Manager
Joel Monge Thu, 07/01/2010 - 09:14
  • Cisco Employee,
Have you restarted the daemons after changing the ANIServer.properties?  I tested the last ANIServer.properties you posted and I had no problems.  Also, I noticed you changed your user but we are talking about the same server, right?
mserranocisco Fri, 07/02/2010 - 02:26
Hi Joel,
it was a database corruption. We had to re-initialize the ANI database.
Thanks for your help.
