4507R_High CPU_Frequently
Jun 29th, 2010
Hi all,
My core switch is choking with high CPU frequently.
There is no routing protocal configured just Static toutes are configured and one PBR.
Request you to help me to resolve this.
Please check the attached logs for reference.
jorge.calvo Wed, 06/30/2010 - 08:39
  • Bronze, 100 points or more
I see from your outputs that the process consuming the CPU cycles is K2FibFlowCache flow which is the PBR cache management process.
1. What is the frequency and duration of the CPU spikes? Do they appear when the traffic rate is high?
2. How complex the route-map and the ACL for PBR is?
Regards.
nyamuthullas Thu, 07/01/2010 - 06:24
Hi Jorge,
Thq for your reply...I agree with you the issue is because of PBR but the PBR was thr since long time i mean 2 to 3 years we didn't find this kind of issue before.we are noticing since 2 months only.
1. No it will go up in non peak hours also.And it will be for some 30 minutes once we reboot the one of the connected switch(Servers connected) then the CPU will go down.
2.
4507R#sh access-list Vlan192
Extended IP access list Vlan192
    10 deny ip x.x.x.x 0.0.255.255 x.x.x.x 0.0.0.255 (1301 matches)
    20 deny ip x.x.x.x 0.0.255.255 x.x.x.x 0.0.0.255 (195 matches)
    30 deny ip x.x.x.x 0.0.255.255 x.x.x.x 0.255.255.255 (2903927 matches)
    40 deny ip x.x.x.x 0.0.255.255 x.x.x.x 0.0.255.255 (58150022 matches)
    50 permit ip x.x.x.x 0.0.255.255 any (7397 matches)
4507R#
4507R#
4507R#sh access-list Vlan16
Extended IP access list Vlan16
4507R#
4507R#sh route-map
route-map internet, permit, sequence 10
  Match clauses:
    ip address (access-lists): Vlan192
  Set clauses:
    ip next-hop x.x.x.x
  Policy routing matches: 7397 packets, 4510260 bytes
route-map simplex, permit, sequence 11
  Match clauses:
    ip address (access-lists): Vlan16
  Set clauses:
    ip next-hop x.x.x.x
  Policy routing matches: 0 packets, 0 bytes
4507R#
nyamuthullas Fri, 07/02/2010 - 02:00
Hi Prasad,
Thq for your reply.
My Switch dosen't support this command.It is running IOS Version 12.2(25)EWA8 and i can't update the IOS for this.
