Cisco 3500 support spanning loopguard default command
Answered Question
Jun 29th, 2010
Hi All,
As per the subject, I would like to know Cisco 3500 series switch support spanning loopguard default command or not ?
Thanks in advance.
Samir
Correct Answer by Leo Laohoo about 6 years 6 months ago
2900/3500XL only has 12.0 IOS and can't proceed any further.  This feature is not supported in this series of switches.  There is no such thing as a "3550XL".
Overall Rating: 5 (1 ratings)
francisco_1 Tue, 06/29/2010 - 09:05
according to Cisco 3550 switch command referece  12.1(14) yes it is supported. The command was first introduced 12.1(9) EA1
Are you having issue?
rana.samir Tue, 06/29/2010 - 09:08
Thanks for your reply.
But I made correction. I would like to know for 3500 XL models. ( 24 port and 48 port)
Waiting for your kind reply.
Samir
francisco_1 Tue, 06/29/2010 - 09:37
on your switch i see 120-5.3. the spanning-tree loopguard command was introdcuced on 12.1(9) EA1. You gonna have to upgrade to minimum 12.1(9) EA1 to support the loopguard command.
Francisco
rana.samir Tue, 06/29/2010 - 09:44
Hi Francisco,
Thank you very much for your early reply.
But I don't think so Cisco 3500XL series support that software.
Samir
francisco_1 Wed, 06/30/2010 - 02:26
correct.
some Cisco IOS commands are either undocumented or not available under specific IOS. Always check the IOS command reference guide.
Francisco.
Correct Answer
Leo Laohoo Tue, 06/29/2010 - 15:20
francisco_1 Wed, 06/30/2010 - 02:21
Common sense should tell you it's a typo mistake.
Francisco
