How to configure CSVB to allow external mail relay using smtp auth
I want to be able to allow SMTP auth based smtp relay from outside the company (for foreign sub-office).
I can see that this should be possible having checked the manual, but I can't quite seem to get it right; has anyone done this before?
Ideally we would want an LDAP authenticated SMTP auth mechanism - we already have the LDAP authentication in place for the spam quarantine.
Thanks in advance, Paul.
Martin Eppler Tue, 06/29/2010 - 12:23
  • Bronze, 100 points or more
Hello Paul,
I'm sorry but SMTP AUTH with LDAP is not supported by the CSVB. Only SMTP AUTH via Forward (GUI: Network -> SMTP Authentication -> Add Profile) is possible. In this case, the presented AUTH string will be forwarded in a new SMTP session to a (backend) mail server for authentication.
To enable SMTP Authentication, you'll need first of all a SMTP Authentication profile, which needs to be configured on the respective Listener configuration (GUI: Network -> Listeners -> (your listener name) -> SMTP Authentication Profile). Once this step has been completed, you'll need to turn on SMTP Authentication in the respective Mail Flow Policies (GUI: Mail Policies -> Mail Flow Policies -> (Policy in question) -> SMTP Authentication: preferred or required depending on your needs).
Hope this helps.
Martin
