06-29-2010 10:25 AM - edited 03-19-2019 01:10 AM
I implemented tcl script on 2801. The script simply answer the call and plays prompt. It works fine when I'm calling from pots. When I'm calling from VoIP I have one way audio and don't hear the prompt. The phone RxCnt stays on 0. Here is part of my config:
voice service voip
application
service aa flash:aa.tcl
paramspace english language en
paramspace english index 1
paramspace english location flash:
paramspace english prefix en
param aa-pilot 5555
dial-peer voice 5555 voip
service aa1
incoming called-number 5555
codec g711ulaw
dial-peer voice 5554 voip
destination-pattern 5555
session target ipv4:10.10.10.1 - (loopback)
dtmf-relay h245-alphanumeric
codec g711ulaw
So when I put the following dial-peer and call from POTS it works:
dial-peer voice 666 pots
service aa1
Please suggest what can be the problem.
Best Regards,
Zdravko Zdravkov
06-30-2010 06:51 AM
Zdravko,
With one-way audio issues, this could definitely be related to an incorrect route on your network. In the non-working case, define which direction the audio is NOT working. For this non-working flow, be sure that every hop in your network from the Source of the stream to the Destination of the stream have a correct route.
The reason why the POTS line likely works is because it isn't routing on your internal network.
Let me know if this helps.
Best Regards,
Kevin
06-30-2010 07:22 AM
I don't have routing issues because I tested the path with CME on both routers and I have two way audio. There is dedicated h323 voip interfaces. There is full routing between two router. I have tested that on two separate environments. I need further advices.
Regards.
06-30-2010 10:03 AM
Zdravk,
Do you have any firewalls in place between the two endpoints? Please let me know your topology. If you have any firewall in place (PIX, ASA, IOS Firewall), be sure that you have H323 inspection enabled and see if you are seeing any packet drops/syslogs indicating the dropped traffic. If you don't have any firewalls in place, I'll defer further responses and troubleshooting ideas to my peers.
Best Regards,
Kevin
06-30-2010 12:34 PM
There isn't firewalls. This is lab environment. I have tested also on production. The scheme is the following:
Phone - CME router <-H323-> Router with script
The problem may come from something related to the type of calls because it works fine on POTS calls but no audio from the script when call comes through VoIP.
I can't see two call legs on the Router with the script. And there isn't also stream to the IP phone.
Regards.
