Errors after upgrading to LMS 3.2
sirbaughmf
I upgraded my servers to LMS 3.2 and
install new certificates signed in-house.  My issue is when I start my services serveral of the RME
related processes are not starting.  CTMJrmServer, UPMDbMonitor, and CWAPublisher.  I have not changed the server name however, I did add DNS to the /etc/nsswitch.conf file and in there the servername is the fully qualified name.  I am seeing some certificate errors where servername is not matching.  Also here is a blurb from the logs:
WARNING: Server certificate chain does not end with trused root cert!
CWAPublisher continues to die.
Running on Solaris 9 with LMS 3.2.
Right now we are down, so any help for be greatly appreciated.
marcie
sirbaughmf
I was able to get most processes running with the exception of CWAPublisher.  I had added Virtual Hosts to the httpd.conf file, once I commented those entries out most processes came back.  CWAPublisher however still will not remain started, fails.  I am also still getting certificate errors.  One last item is that when I run the cwcli command to get inventory, I get no results even though there are devices in RME.
