06-29-2010 11:06 AM - edited 03-11-2019 11:05 AM
I have pix 515E that a proxy server hits to go out to the internet. The issue Pix I have it set up that anything on the
192.168.5.0/24 subnet gets NATTed to the public IP of 38.125.160.200 and all works find and all. The proxy server's
IP address is 192.168.5.8. The issue that I found out was that on the inboud side found out that there is a static
NAT
static (inside,outside) 64.77.50.24 192.168.5.8 dns netmask 255.255.255.255
which causes our back ups to not work cause the third party is expecting a 38.125.160.200 but instead they see
this 64.77.50.24. The simple solution is to get ride of that static but I was told that will screw up in bound connections
going to the Proxy server. Is there any way that I can say anything
coming from the 192.168.5.8 address going outbond will be natted to the public IP of 38.125.160.200
and the inbound will remain as is:
Thank you in advance for your help!!!
Solved! Go to Solution.
06-29-2010 12:51 PM
Yes. you can accomplish this but not with what you have already configured.
If you change this 1-1 static for inbound for specific tcp or udp ports
static (inside,outside) tcp 64.77.50.24 8080 192.168.5.8 8080 netmask 255.255.255.255
then you can add
nat (inside) 100 192.168.5.8 255.255.255.255
global (outside) 100 38.125.160.200
This will make the host 192.168.5.8 look like 38.125.160.200 for outbound and for inbound 64.77.50.24 will work.
-KS
06-29-2010 12:51 PM
then you can add
-KS
06-29-2010 02:23 PM
Thanks for the info!!!! will give that a shot
