unable to login CAD
Jun 29th, 2010
In a cluster of 1 call manager publisher and 1 call manager subscriber the publisher goes down. During this downtime the call center agents are unable to login to CAD. What can be the possible reason behind it and how to overcome such situation.
Overall Rating: 5 (2 ratings)
Walter Solano Tue, 06/29/2010 - 12:12
  • Gold, 750 points or more
Hello
Do you have both server under the CUCM cofiguration in UCCX??
Please rate this post if was helpful
Walter Solano
CCVP, Cisco UCCX Specialist
Cisco IP Communications Express Specialist
Aaron Harrison Tue, 06/29/2010 - 12:24
  • Community Spotlight Award,
    Member's Choice, May 2015
This is quite a common error - by default the CCM you specify when you set up the cluster is added as the AXL server, and it doesn't prompt you for a secondary.
Go into appadmin, then System/Unifed CM Configuration.
- On that page, ensure that there is at least two AXL servers selected (also in CCMServiceability - http://callmanagerip/ccmservice - that you have activated the AXL service on the servers you select)
- Also ensure that the CM telephony subsystem and RMCM  subsystem have at least two servers. Again, in CCMServicebility ensure that the CTIManager service is activated on both the servers you select here.
Aaron
Please rate helpful posts...
SJ SJ Thu, 07/01/2010 - 12:47
I m using ipccx 6.X version I dont find any option for secondary provider or something like that. Attached snapshot of CRS.
Please suggest !
Aaron Harrison Thu, 07/01/2010 - 13:05
Yes, 6.x is an oddity... it works a bit different as it's built for CM4.3 so no AXL, just DCD.
Firstly - the JTAPI and RM screens you grabbed should have two CCMs listed, seperated by commas. As pointed out earlier, both those servers MUST run the CTIManager service.
Secondly - on the LDAP page, you do the same thing - specify the two CCMs, listed seperated by commas. Both will already run DCD.
I think the screen you grabbed for LDAP was System/LDAP? There was also in older versions another place to enter the info under 'Tools'/'User Management'. Do the same thing there is there is a similar field.
Aaron
SJ SJ Wed, 07/07/2010 - 12:59
Can someone tell me the exact steps that i need to follow to add the ip of second CCM ver 4.3 in IPCCX ver  6.x , keeping in view
that the server is in production.
Thanks.
Aaron Harrison Thu, 07/08/2010 - 02:55
Were you not able to find the three places I listed above?>
Aaron
SJ SJ Thu, 07/08/2010 - 05:34
yep aaron i found,  i found 2 more places where ldap ip need to be added , i've attached those. Please check and confirm.
I actually want to make sure that we only have to add a comma and then the ip of subscriber everywhere,  also please let me know
that on secondary CRS server do i have to do the same changes or not.
Thanx for your help Aaron.
Aaron Harrison Thu, 07/08/2010 - 06:43
You don't need to go into the Serviceability tool to do this; all the places you need to change are in AppAdmin.
Were you able to find those settings I referenced in AppAdmin?
Aaron
SJ SJ Thu, 07/08/2010 - 21:43
Yes i found those settings in appadmin.
