Ezvpn headquarter network with a home network using same outside interface
Jun 29th, 2010
    Hello all,
I am trying to use a cisco 800 series router to configure two seperate vlans for a teleworker. One vlan will be the Corporate network and the other vlan will be the home network. I have SVIs setup for each network. Nat statements on the Home network SVI for inside and NAT outside on the outside interface that will use DHCP from DSL or cable modem. On the Corporate SVI I have the crypto ezvpn inside statement and on the same Outside interface I have the crypto ezvpn outside statement..
The VPN connects fine but it is trying to NAT my home network through the tunnel. Is there a way I can split the use of the outside interface so home traffic simply gets Patted to the dhcp given address and any traffic on the Corporate vlan goes over the ezvpn tunnel?
John Blakley Tue, 06/29/2010 - 12:57
  • Purple, 4500 points or more
Can you post your nat config? (Route maps/nat statements/access-lists)
John
Related Content
