Unable to configure vtp mode transparent on Cisco 3548
Answered Question
Jun 29th, 2010
I'm unable to configure "vtp mode transparent" on a Cisco 3548-XL switch.  It's using IOS c3500XL-c3h2s-mz.120-5.WC3b.bin.  The only options under vtp is "file".
switch(config)# vtp ?
file
Please let me know if I have to upgrade the IOS or removing the vlan.dat file.  This switch was not properly reset to manufacturer's default.  I was given time to reset.
-Manny
Correct Answer by Leo Laohoo about 6 years 7 months ago
It won't.  2900XL/3500XL does not support extended VLAN.
Extended VLANs support starts with the 2940/2950/2955 using version 12.1(22)EA5 and later.
Overall Rating: 5 (1 ratings)
Edison Ortiz Tue, 06/29/2010 - 14:27
Very old IOS.
You need to get into 'vlan database' in order to change the VTP mode.
For instance:
switch#vlan data
switch#(vlan)vtp ?
Edison
fibernet570 Tue, 06/29/2010 - 15:22
I need the extended VLAN range, I only see 1-1005, is this a hardware limitation?
-Manny
Leo Laohoo Tue, 06/29/2010 - 15:11
Yes you can.  You have to get into the VLAN database (old-fashion way):
Switch#vlan database
Switch(vlan)#vtp transparent
exit
Hope this helps.  Please don't forget to rate useful posts.  Thanks.
Correct Answer
Leo Laohoo Tue, 06/29/2010 - 15:40
