Proxy Server DMS 5.2 ??
Answered Question
Jun 29th, 2010
I have my DMS running in a network that navigates through a Proxy Server, is there a way to configure it in the DMM and SnS. I have seen the option in DMPs but not in the servers.
I need it so that I can publish web pages and RSS.
Thanks!
Correct Answer by Tomas De Leon about 6 years 7 months ago
The DMM & SnS cannot be configured for Proxy use.
This is a known issue.
Check out:
CSCte67952 - DMD:  RSS will not work after upgrade to 5.2
Symptom:
The RSS ticker is not showing some content after upgrading to 5.2.
This is because DMD in version 5.2 uses Flash to display the RSS ticker
And the Flash 9 and 10 player has built in security to not allow content
from another domain.
This security feature is blocking the content.
Workaround:
There are several options available:
1: Only use RSS feeds from sites that allow cross site scripting.
2: Use a service line "Yahoo Pipes" service that acts as a proxy. This
   will result in a a new URL that can be used in the DMD, bypassing
   any cross-site scripting.
Additional Note:
If you use the standard RSS feed in the Signage Design tool, it will work
with any RSS feed you have and you don't need a crossdomain policy file.
Cross Domain refers only to Adobe Flash Player and the ability to read
content from other domains. Its a security issue
As an example:
If your SWF file is hosted on www.cisco.com/flash/myflash.swf
And that SWF want to read any content (xml, rss, etc..) from rss.cisco.com/myrss/xml
That is allowed. If that same SWF file tries to access data on www.google.com/somedata.x
ml That would require a crossdomain.xml at cisco.com/crossdomain.xml that
lists google.com  This allows the Flash player to access content at google.com
http://kb2.adobe.com/cps/142/tn_14213.html#policy
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Overall Rating: 5 (1 ratings)
Correct Answer
Tomas De Leon Wed, 06/30/2010 - 09:42
Check out:
Symptom:
Workaround:
Additional Note:
As an example:
Thank You!
T.
