VPN client connot communicate with anothe VPN client - ASA
Jun 29th, 2010
Any suggestions as to why my vpn client users cannot communicate with other VPN client connected users? In other words peer to peer communication.
Walter Lopez Tue, 06/29/2010 - 20:03
  • Cisco Employee,
Some suggestions:
1. Be sure you have the command (it will allow you to U-Turn in the ASA):
- same-security-traffic permit intra-interface
2. If using Split-Tunnel, be sure you have the Pool of the VPN Clients in the Split-Tunnel ACL under the group-policy.
3. Check (Disable) any firewall or anti-virus on the computers.
4. Check if the packets are going through the other VPN Client connection you are trying to reach, use the command:
- show crypto ipsec sa
5. Take captures on the ASA to confirm if the firewall is not dropping the ICMP Packets:
-- capture asp type asp-drop all
--> show capture asp | inc
