need help in loading IOS on 3750
Jun 29th, 2010
Hi all,
can anyone help me on what command i will execute on hyperterminal to copy the IOS from my pc to switch.
My problem is that the switch does not boot because the flash was not found.
I downloaded a flash but i dont know how to copy it from my pc to the switch using hyperterminal.
when i type this command:
switch: copy ?
this will show
usage: copy [-b <buffer_size>] <src_file> <dst_file>
what does buffer size mean and can someonegive me an example command on how to execute that command.
Please someone help me......
Leo Laohoo Tue, 06/29/2010 - 16:55
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
You can try to "download" the IOS via the console cable using XModem, particularly the switch command  "xmodem -r -s 115200".  This command means that the IOS will be loaded into the DRAM (-r switch) and the upload will be using high speed at 115200 bps (-s switch).
Xmodem Console Download Procedure Using ROMmon
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
Hope this helps.
Please don't forget to rate useful posts.  Thanks.
